I have vulcan ducted heated model no. 9255. The comfort control is reading the room temp as 35C when it is actually 11C, yes its freezing here. As the room temp is at its maximum reading the heating is not working. I have tried removing the batteries and restarting, the reset button and resetting the identity code, all to no avail. help! Patricia
I replaced the batteries, even though 'battery low' message was not displayed. this fixed my problem. I wish I'd have just done that to start with.
Posted on Aug 13, 2008
I HAVE A MODEL HOE-HT-L2 THE INSRTUCTIONS ARE NOT CLEAR AS TO SET THE TEMP CONTROLS
Greeting Cyril Hrachovy,
"Say" 22 is an example... You should input whatever temperature where you are comfortable ...
Our master bed room has it's own controls... but usually the vents have been blocked shut... or have magnetic diverters (plastic shields) on the vents... where the thermostat is all warm & happy across the room while I'm freezing against the glass...
A happy medium has to be struck
- between the IVORY-TOWER instruction writer... and
the sun soaked rain drenched REAL WORLD in which
we live (I'm just saying).
Programmable THERMOSTATS are get (fun)... but in reality
the automatic features are soon abandoned... (harmony)
and the REMOTE favors the fickle.
Carnac the Magnificent
Jan 01, 2017 | Heating & Cooling
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
Jun 20, 2016 | Heating & Cooling
F1 08 f2 08 f3 08 f4 08 error codes vulcan comfort control what does it mean
What sort of machine is it? Refrigerated, Ducted, Gas? To do a full reset correctly, you must switch off at the main isolator next to the unit or at the meter box and leave it off for at least 15 minutes. A quick on / off does not reset it properly. If the unit is a refrigerated split system , and the outdoor is running but the machine is not blowing cold outside and hot inside (On heating mode) It could be due to a gas leak / shortage.
May 26, 2015 | Heating & Cooling
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
In the last couple of days the air temp reading on the dehumidifyer has been off by about 10 degrees compared to the actual temp in the room. Room temp is 10 degrees higher than what is being shown on the...
It may simply be a case of where the unit is sitting, as opposed to where the thermostat is, that you're getting the higher reading from. Is that thermostat subject to direct sunlight? Is it near a heat producing appliance (i.e a lamp, a heat duct or air return duct). Any of these things could account for the difference in temperature. As could restricted air flow around the unit.
Actually, I not sure that the temperature reading plays a big role in the operation of the dehumidifier. As the same LED read out, is also the timer read out.
Of course if you have further concerns about it, you can contact Haier Customer Support at 877-337-3639.
I hope this helped you. Please let me know. Thanks
May 03, 2011 | Haier 45-Pint Dehumidifier
Our remote control for Vulcan Comfort Control Gas Ducted Heating is broken and we need a replacement, where can I find one as Bonair/Vulcan no longer makes this model and their spare parts business cannot...
Try Skytech Systems. They make a remote control for just about anything. And one of theirs may be adaptable to what you need. http://www.skytechsystem.com/ If you don't find what you're looking for on their website, call them and talk to Customer Service.
Mar 31, 2011 | Heating & Cooling
Got a pyrox comfort control ducted gas heating system cant heat house above 19 dec have to keep hitting reset button every 10 mins, have cleaned the filter still doing the same, have heard the comfort...
on the reset switch there should be a temp. cut out take a temp. reading and see if it is realy getting as hot as the switch is rated for maybe the switch is bad
Aug 11, 2010 | Heating & Cooling
Is vulcan duct heater still in existence? My problem is the thermostat control for the room temp has gone out of control - from 22 -35 0C. This has affected the heater cut off efficiency.
Yes. Vulcan heater company is still making heaters. Here is the link. http://www.vulcanelectric.com/
Grainger is a direct seller of Vulcan heaters, so you chould be able to give them a call, explain what you need or giver them a part number and they will be able to get what you need.
May 12, 2010 | Vulcan AUW230A Heater
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Heating & Cooling Logo
656 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
