Question about Maxtor MaXLine Plus II 250 GB Hard Drive
Audiable tone from the inside of my Maxtor HD
My Maxtor 250G Ext HD , Model # 6L250R0 was accidently dropped , from only 2 feet,and started emitting this awful tone from the inside of the unit.The tone was a digital sounding tone. When I connected it to my laptop , my laptop wouldn't recognize it. I tried it on a few other laptops and the same things happened , it did not recognise the unit and the same noise was heard. As soon as the power supply is plugged in and the unit is turned on it keeps making that awful noise for a few seconds and then stops. As well the motor doen't turn at all.What can I do to retrieve my valuable documents and family photos????
  • 162 Answers
Well thats a toughie, theres a recovery company that will pull the platter's out and install it into a functional drive, recovery experts or something. You can try it yourself but it's delicate on a laptop drive but not impossible.
Posted on Aug 12, 2008
I-series enclosure won't work properly with maxtor 4D040H2
I have two suggestions.
  • First check and clean your connections.
  • Update your drivers by CLICKING HERE.
  • Lastly, let Microsoft scan your operating system and fix, if necessary, any problems in three easy clicks. CLICK HERE
Apr 29, 2012 | Maxtor Hard Drive
Bad block on 250gb Maxtor Hard Drive 6l250r0
Hardware defect = an actual spot on the disk is damaged. This is going to get a lot worse quickly so save all your files and replace the hard disk ASAP.
Dec 21, 2010 | Maxtor (6L250R0) 250 GB Hard Drive
Hey , i have had the maxtor 6l250r0 for a few years now with no problems.I turned it on this morning and it started beeping for about ten seconds , the compter makes the usual noise when it conects with it...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty
then you might run the click start run typ cmd then type chckdsk/r/f which will scan for and attempt recover any bad sectors and automatically fix any bad/corrupt files on your hard drive
hope this helps
Dec 12, 2010 | Maxtor (6L250R0) 250 GB Hard Drive
My Maxtor 3200 possibly has failed. The green light does not come on and my computer no longer shows it connector asa ext HD. Any recommendations.
I agree that it has failed.
Get the model-number and serial-number from the label on the disk-drive (by opening the enclosure) and use the "check warranty status" utility on Maxtor's web-site, to see if the warranty still is valid. If it is, Maxtor will repair/replace the unit, at minimal cost to you.
Nov 01, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3100 ext. HD (200 GB). When plug into electrical outlet, the on light does not come on, and when connected to my PC, it doesn't recognize it. I think the power cord is defective....
You can find a power cord for your Maxtor Personal Storage 3100 100 GB Hard Drive here:
http://lcdpayless.com/productpage.php?productId=2503
or
http://www.ecrater.com/p/6553550/ac-dc-power-adapter-maxtor-3100
Oct 31, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Lacie 1tb ext hd. drive does not show in disk
Your external drive has 2 parts, the hard drive, which is just a normal hard drive you would find in any computer, and the usb bridge, which connects the hard drive interface (either ide or usb) to the usb or firewire or esata or whatever. Sounds like one of these are bad. Does the computer see the bridge? it should show up as a mass storage device in device manager and the safely remove usb devices dialog. If not, then get a new enclosure for the drive. These range from 25-100 dollars. If the bridge does show up, take apart the enclosure and pull the drive out and try hooking it up as a second drive in your computer. If it works there, then you need a new enclosure. If not, then you need a new drive.
Dec 07, 2009 | LaCie Computers & Internet
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Need drivers for a Maxtor 80GB Onetouch III Mini edition
I have a Maxtor Ext HD myself. Maxtor has a website. Try www.maxtor.com or Google it and you will find their web site. Then search for your HD and do a search for the download of the drivers needed for your HD
Mar 13, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Musical tones from Maxtor Diamondmax 10 Model 6V250F0
All hard drives are about as delicate as an egg when they're running. It's dead. You can pay a data recovery company to retrieve what little of the data is still intact, but it will cost you a lot of money - not worth it unless there's something particularely precious on it.
Whether the beep is an actual speaker inside the drive that beeps when a serious error is detected, or if it is just a side-effect of the heads scraping on the platters, is of little importance.
For your next drive, buy a good one. I buy almost exclusively from Seagate and WD. Maxtor just doesn't make good hard drives.
Nov 20, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Maxtor mini iii 120 gb HD
Uninstall the back up software, and choose another or reinstall it.
Oct 17, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor MaXLine Plus II 250 GB Hard Drive Logo
184 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
