Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Check paper When I send a fax it says check paper but it does go through. I tried to receive a fax and it said check paper. Ann
  • 24 Answers
Change feed rollder or rub them..........
Posted on Sep 29, 2008
Cant Send or Receiver. Message says Check Printer
Any numerical code displayed with 'check printer'?
Dec 16, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
I cannot fax with my Lexmark 2500 after installing Windows 7
If Cannot send or receive Fax :
1) Check the control panel for any blinking lights. If the lights are blinking then
The color print cartridge needs to be replaced soon.
2) Check power.
a) Disconnect the power cord from the wall outlet, thenfrom the printer.
b) plug the cord all the way into the power supply on the printer.
c) Plug the cord into an eletrical outlet that other electrical devices have been using.
3) Check Cable connections Make sure cable connections for the following hardware are secure, if applicable
* Power supply
*Answering machine
4) Verify dial tone.
* Place a test call to the telephone number to which you want to send a fax to make sure that it is working correctly.
*IF the telephne line is being used by another device, wait until the other device is finished before sending the fax.
5) Check for paper jams. Check for and clear any paper jams.
6) Disable Call Waiting Temporily. Call waiting can disrupt fax transmissions. Disable this feature before sending or receiving a fax. Call your telephone company to obtain the keypad sequence for temporarily disabling the call waiting.
Can send but not receive faxes
1) Load paper. Load paper to print any faxes that have been stored in the computer.
2) Check ink. Check the ink levels, and install a new cartrige of necessary.
Can receive nut not send faxes
Check document placement. Load the original document facedown in the lower right corner of the scanner glass.
Hope this help. Please Rate My Response!
Nov 23, 2009 | Lexmark Wheelwriter 2500 Typewriter
Fax sent is received in blank
Here is a possiable problem you got the paper in the wroung way or your lamp is not working check both~)
Jun 22, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
HI.when u try to receive or send any fax.fax gives any msg r not.first check ur telephone line.u have to connect it in line.there are two places in fax .one is ext and second is line.check it u r putting it line.for receiving check auto answer .put it on fax only mode.u will receive fax.MIAN AKHLAQ.if it helps rate the solution.
May 16, 2009 | Panasonic KX-FPG381 Plain Paper Thermal...
Not receiving faxes
Folio is not what you want. The usual is letter (LTR) or 8.5 x 11. You may have to check the settings to set the default paper size.
Jan 14, 2009 | Canon PC-1080F Plain Paper Laser Fax
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Can send but cannot receive fax
check it is in fax mode in setting ------try to clean with air blower and soft cloths------check inside for any foreign object droped inside(pins--stapler-any small pieces of torn paper.------check microswitches in paper path for broken lever and test it with your hand and feel free moving.
Apr 28, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Hp T65 program to receive faxes
press setup and change the following settings
basic fax settings:
1. auto answer : ON
2. Rings to answer = 3 rings (recommended)
Advanced fax settings:
1. distinctive ring pattern = all rings
2. ECM = OFF
3. Fax speed = slow
Feb 02, 2008 | HP OfficeJet t65 All-In-One InkJet Printer
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
59 people viewed this question
James Cagle
James Cagle
Jim Keysor
