Question about Dacor Epicure ESG366 Gas Cooktop
Igniter not working
Curiously, one day the igniters for my gas cooktop ceased working. For whatever reason, they do not click, obviously not working. The cooktop is appoximately 9 years old but otherwise works fabulously. I have been very happy up to this point with the product. Reading one of the similar situations from another consumer nakes me nervous - is it really not a do-it-yourself repair? If you can shed any light on the subject, I would appreciate it. Thanks so much.
3 Suggested Answers
SOURCE: Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Posted on Apr 28, 2009
SOURCE: Dacor gas range igniter clicking
I had clicking after the burners were burning. Problem was that I'd removed the inner ring during cleaning and did not put it back properly. There are little nubs that must be lined up properly. If you don't, ALL the burners can start to act wonky when you try to ignite them. Problem solved.
http://www.fixya.com/support/t1067772-jen_air_gas_range_igniter_keeps_clicking
Posted on Mar 04, 2010
heatman101
  • 43501 Answers
SOURCE: I have a 5 burner
The switch behind the knob is bad..
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
On a 4 burner Gas cooktop - all 4 burners get gas but why does the igniter only work with the front 2?
Usually that's caused by clogged holes in the burners. I clean it out using a toothpick.
May 02, 2015 | Jenn-Air Cooktops
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
We had a power outage for several days. Now that power is back on, the electric igniter will not work. We have to light the burners manually. There is no "clicking sound" indicating the...
See where the range is plugged in. Check to see if there is power there. If so, the igniter must be replaced. This is not a difficult repair. I would guess there is a power problem, blown circuit breaker, open GFCI outlet or the plug is out.
Gary
Sep 01, 2011 | Jenn-Air 30 in. CCG2423 Gas Cooktop
My cooktop igniter keeps on igniting for no reason
This problem is due to a short to wires contact on the igniter sometimes this happens after a cleaning of the cook top with water so in this case you just use hair dryer and dry out the ingniter.
Other possible reasons are over heating of the ingniter contact so you have to remove it and clean wire contacts.
Finally the igniter contacts are melt together or sometimes full of burned oil and they need to be replaced. Inginter is not expensive part.
Oct 02, 2010 | Baumatic 34 in. B17.5 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Ignition is clicking all the time, whether the gas is lit or not.
The clicking is the igniter. If it is clicking and not lighting, then you may have to purchase an igniter kit and replace it. the relays can go bad, or igniter fails.
Sep 04, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Jennair CCG2523 Gas Cooktop
igniters fire continully any time knobs are on, even after burners
are lighted.
Sep 18, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Dacor Epicure ESG366 Gas Cooktop Logo
57 people viewed this question
Top Dacor Cooktops Experts
meztang
meztang
Lakeland Appliance...
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
