Question about Samsung Washing Machines
Samsung Washer #WF316LAW/XAA
When you remove the top cover to the washer, there is, in plain view, a clear plastic box right in the middle, attached with 2 screws to the support bracket that sits right above the tub. There are 3-4 small hoses that come from the dispenser over to this box. We have not been able to find that box or a part number or a drawing that explains what it is and where we can purchase it. The box is leaking from the bottom side and can not be repaired. I hope you can help us out.
Thanks in advance.
Rex H
ACE Appliance
Bloomington, IN
Sears parts will have the drawings
Posted on Dec 08, 2009
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Samsung washer ND code and not drain and spin
Sounds like control Board isn't sending voltage to pump. Most likely a control issue.
Nov 03, 2017 | Samsung Washing Machines
WHERE IS THE CLOTHES WASSHER WATER LEVEL SWITCH LOCATED ON WHIRLPOOL DUET FRONT LOAD WASHER MODEL #WFW9600TA00
The water level switch (also known as a pressure switch) can be accessed by following these steps:
1. UNPLUG the washer.
2. Remove the top panel of the washer by locating and removing the three screws holding it in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
3. With the top panel removed, the pressure switch will be located on the RIGHT-HAND side towards the rear. The switch is usually brown or gray in color and will be mounted to the side of the washer cabinet.
You can reference helpful exploded view parts diagrams at searspartsdirect.com. The pressure switch is referenced as item number 20 (part number W10156252). There is a substitution part number from the manufacturer available as well - W10312527.
NOTE: You can use the following websites as well:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If your model number does not cross reference to some of these websites, use the part number(s) for your search criteria. The model numbers may not always be available on every site, but the part numbers usually will cross reference.
FYI: BEFORE assuming the switch to be defective, double check to ensure the plastic air hose leading to the switch is still attached and not ripped or torn anywhere. If the air hose has come loose, or if it has any leaks, the pressure switch will not function properly and the washer will continue to fill and not shut off.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Nov 11, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
How do I replace the oring gasket on a front loading samsung wash machine model number wf219anw/xaa
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
Aug 11, 2010 | Samsung WF337AA Front Load Washer
LG Front Loading washer detergent drawer is jammed and will not open
you're in a bad spot. you will need to remove top metal panel of washer; and carefully separate the drawer housing a little and wiggle the drawer out. one of the compartments in the drawer popped up and jammed the drawer.
Feb 15, 2010 | LG WM-2277HW Front Load Washer
How do I replace the battery and where is it located?
Procedure:
Remove battery cover located under the hood on the passenger side in the back. Simply pry the plastic catch in the front, open it like a lid and jiggle it loose and set it aside.
Use the small flat screwdriver to pop up the center peg in the five peripheral fasteners holding down the plastic compartment cover that you just removed the battery cover from. Each of these has a small black plastic circular flat topped center peg inside a larger plastic circular disk which has 4 slots under which you can slide the screwdriver to pop up the center peg. When the peg pops up simply slide the screwdriver under the larger disk to remove the assembly and loosen that site of fixation. When all five fasteners are out you can remove the entire compartment cover.
The battery terminals are removed with the 10mm wrench
The black box in front of the battery can be lifted out of the way by pressing on the plastic catch in the front of the box to loosen it from the metal flange that it is attached to.
The metal battery holder is removed with the 10 mm wrench. The nut is removed and the long bolt is slid out of the holder and then unhooked from it's bottom anchor. Jiggle the metal bar over the top of the battery to unhook the back hook from its bottom anchor. It may be necessary to lift the plastic over the back of the battery gently and lift out the soft clear plastic washer fluid tube from its guides to get at the back hook.
Gently lift the battery out while holding the cables out of the way.
Tools required:
10mm wrench, small flat screwdriver
Procedure:
Tools required:
Procedure:
Tools required:
Procedure:
Apr 17, 2009 | 2004 Nissan 350Z
Howdo i get the washer cover off a thintwin whirlpool washer tha
the timer box or the whole washing cabinet cover?
the timer box is removed via 2 screws in the rear of the plastic end caps and carefully wiggling it foward very gently then it should tip back...
if you want the cabinet removed under the timer box is 2 metal snaps that can be removed to take off the outter cabinet.. good luck
Feb 15, 2009 | Whirlpool LSB6200PQ Top Load Washer
Whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Jun 28, 2008 | Whirlpool GHW9400 Duet Washer
TOP LOAD WHIRLPOOL WASHER BRAND NEW CRACK IN OUTER PLASTIC TUB.
loosen the screw bolt located at the back cover,it has also a plastic lock in the side to side of the plastic cover,find it by sliding a small flat srew.
Feb 21, 2008 | Whirlpool LSQ9610L Top Load Washer
Washing Machines Logo
497 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
