Question about Dell Inspiron 8600 Notebook
Setting up a wireless router
How do I set it up with comcast ?
    Genius:
  • 2,028 Answers
If this router was supplied by Comcast it should have come with directions. Comcast has excellent customer support, and should be able to get a technician to you within a day without any service charge. If this is a router that you're supplying yourself, you will want to contact Comcast for compatibility. They can send a technician, but they will likely charge a service fee.
Other than that, all I can give you is, the router needs power, line in from the cable box internet line out port, and on some line out from the router to the line in on the box for data transfer. Comcast in some areas offers a help channel for internet connection hook up and troubleshooting.
Posted on Aug 12, 2008
  • 3,940 Answers
Here are some pretty good instructions from Microsoft:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
My router isn't sending a wireless signal. just setup internet with comcast and now the router isnt sending ethernet wireless
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jul 21, 2010 | Linksys Wireless-G Broadband Router
Set up difficulties
You sure can. Start w/ the Comcast modem as long as it is NOT a USB type and hooks using a CAT-5 cable (regular network cable). Hook the comcast modem to the WAN port of the wireless router. On the back of the wireless router use the normal 1-4 extra LAN ports to hook other computers or the SD208 switch to it and other computers from there.
Word of advise if using Wireless Router, be sure to read manual and set a KEY for your network to secure it from unwanted outside use.
Apr 03, 2010 | Linksys SD208 8-Port Ethernet Switch...
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
How do I hook d link up to my comcast router so that I can use it with my laptop?
Well, you are trying to connect a router to a router, that can be difficult. Is there anyway you can exchange the Dlink router for a Wireless Access Point (AP)? If you can, you just connect the AP to the 4-port network side of the comcast router, configure the wifi settings (security, etc), and you're good to go.
If you can't exchange it, then your best bet is to connect the 4-port (or internal) side of the dlink router to the 4-port side of the comcast router. Then the dlink will be seen by the comcast router as another internal connection, and you can set the wifi settings of the dlink at that point. If you connect the dlink to the comcast router via the External port on the dlink, then you are creating two separate IP subnets, a needless complex setup.
Nov 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I'm trying to connect a netgear wpn 824 to a comcast router with windows 7
You are trying to set up the wireless router with the comcast modem, right ?
You can set up the router manually , without the disc.
Make sure that your computer is able to go online when connected to the comcast modem only.
If you have the router working already then you just need to add a computer to the network.
Click Here for step by step solution
Oct 27, 2009 | NetGear RangeMax WPN824 Router
No more internet thru router after new modem installed
Router setup
Go to the control panel and un-install the program that the Comcast cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Did Comcast reset you wireless router settings? If so, you may need to set up your SSID and security settings.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 05, 2009 | Linksys Wireless-G WRT54G Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Setting up a zyxel router
Do you have a wireless card on the PC's and a wireless router connected to Comcast Broadband. If so read the Zyxel manual. It should have some straightforward instruction. Use DHCP.
Aug 26, 2008 | Zyxel Prestige P-330W Wireless Router...
Dell Inspiron 8600 Notebook Logo
77 people viewed this question
Alun Cox
