Question about Hitachi 43UWX10B 43" Rear Projection Television
Bowed pink and green lines
Hi,You were kind enough to suggest calling a repairman.Are ic's expensive?Tv is 8 years old.Thanks,Todd tjkelly67@gmail.com
  • 927 Answers
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Posted on Aug 19, 2008
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
GREEN BOWED LINES
You have a convergence problem Call a Sony service center make sure they use original ic's in this model cost is around 350.00 depending on area.
Apr 13, 2009 | Sony Grand WEGA KDP-57WS550 57" Rear...
Sony KP-53HS10 - Green & pink halos & picture "bowed" on edges
you will need to replace the convergence IC's and test resistors on them for bad values , if you want to do the repair yourself
otherwise to have a tech come out and do the repair will be about $300
Dec 12, 2008 | Sony KP-53HS10 TV
KP-61HS30 Sony TV turn pink and green text is bowed
Check out CONVERGENCE GALLERY . If you see your symptoms you have a problem in your convergence amplifier circuits. Typical Sony Convergence repair requires disassembly for replacement of 2 ICs, sometimes a fuse or 2, then TV is like new.
It is much more complicated than changing batteries on your remote. Many consumers try unsuccessfully to do a convergence repair. I recommend finding someone competent to do it for a reasonable price. Typical repair shop charges may be from $400 to $650.
If you are in the Calgary area, call me. More reasonable rates.
easyab
Jul 31, 2008 | Sony KP-41T65 41" Rear Projection...
Hitachi tv
You need to call a tv repair person.The set needs new convergence ic's an updated resistors.This is a common failure and they have a update kit to help increase performance.
Jul 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Philips 55P8342 Bow in picture
Replacement IC's suspect...did you use generic ? For all my repairs where originals are STK392-110,120 or 150....I use the
up-grade STK394-160E Mfr by SANYO with Hitachi part number
CZ 01341...they are expensive,but NO RE-CALLS ! Also,did
you check the resistors close to the IC's for over-heat damage ?
...........................................T.
Feb 21, 2008 | Philips 60P8342 60" Rear Projection...
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
Another Convergence Problem?
dont move the pic tubes that will be a costly mistake the problem is still your ics replace them all you should have two check for bad solder connections
Nov 12, 2006 | Toshiba 50HX70 50" Rear Projection...
Red lines
The top of my screen is pink and the color kind of bows down. The images are kind of distorted. Thanks for any help.
Sep 28, 2006 | Akai PT5598HD 55" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
