Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Panafax uf 755e
How do i get it to print fax confirmations
    Genius:
  • 2,120 Answers
Function 74 set 12 set 2 set stop
Posted on Aug 31, 2008
SOURCE:
I have a panafax UF-755E will not accept multiple pages. I have to feed them one at a time? Any suggestions on how to fix this problem?
Pana fax uses a thin peice of rubber to prevent multiple sheets from feeding these wear out.
You can try opening the part where you feed your origials and clean the rubber roller and pad with soap and water and a damp cloth
or
I remember having some luck flipping the ruber pad over
or you can order a replacement here....2nd item down
http://www.worldoffax.com/PANASONIC%20UF%20755E.htm
Apr 14, 2010 | Panasonic Panafax UF-885 Plain Paper Laser...
Hello i have a panafax uf-280m i would like to
Sometimes you can go to "print reports" then activity report and print your send report
Mar 23, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Print out confirmation with image on page
press
function
7
monitor key slowly 4 times
set
look on the sheet for confirmation + image parameter
set with above procedure but use number 74
set
Feb 04, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax UF-755e
Sometimes when this machine loses power it goes to a default setting (flashing time and date) You will need to got to the user parameters and reset the time and date. If you refer to your user manual it will tell you how to do this.
Hope this helps...
Jun 16, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
74 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
