Question about Jensen Car Audio & Video
Jenson touch screen head unit is all hooked up properly in a 2001 honda civic if i turn it up to around 25 with loud off and bass down it will shut off for a few seconds and then turn back on and repeat till i turn it down if loud and bass are turned up it will do this at lower volumes i know i have some sort of power issue any help will be greatly appreciated
  • 53 Answers
The onboard amp in the deck can't keep up and overheats inturn shutting off the speakers , this is common in jensen touchscreens esp the 9412 9512 and the uv 8 best thing to do is buy a 4 channel amp and the problem will be solved sometimes running a bigger constant power wire to the deck will help a little but not much better off buying a 4 ch amp
Posted on Aug 12, 2008
2001 Civic dimmer not working
It's not high and low beam, it's the dash lights that are dim. I've hooked up many aftermarket radios but never knew it was a no no to hook up the dimmer/illumination orange wires in a '01 civic. I googled it and seen many others with similar issues like mine but nothing exactly like the issue I have.
All the dash lights work, they are dim though. The radio lights work but they are even more dim than the rest of the dash lights. I have check every single fuse under the dash and in the engine bay. The dim controller does not work at all now. I'm guessing that's the issue and from what I read, the dimmers circuit board is in the instrument cluster. Some can fix it, others can't.
I will probably end up buying a used instrument cluster off of ebay, they are not expensive. Hopefully that fixes it since everything else works.
Oh, yes, the brake lights work.
Ted, I think you answered the wrong question...I mentioned nothing about the battery or the low/hi beams
Aug 13, 2012 | 2001 Honda Civic
The amp worked fine for about a year then one day the bass would not play through my subs properly sounding like a cd skipping only with the bass i would turn volume down and it would work fine until a...
When you hooked up your amp, did you hook it directly to the head unit so that it didn't come on with the car? Did you find the inline fuse in the amp positive cable? Few things to check..
Jul 13, 2017 | Kenwood KAC-6104D D Class Mono Power...
I have a 1200 watt sony xplod amp hooked up to a 15" SBL Gorilla sub. The bass hit for a while and then started to cut off. Now it wont work unless i touch the remote wire to the power wire, and even then...
this kind of problems usually happen when the amp is not getting enough current to power up the
 amp. the moment a loud low frequency hits the amp it fails. cud be ur power unit not giving enough power to the amp or u have a loose connection somewhere on ur power line. besides 8gauge is a bit small. try using about 4gauge. should have good ground too. they draw large current so ur battery should be in top condition as well.
Mar 21, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Replacing fuse on 2001 Honda Civic Instrument panel
Use fuse size listed on fuse panel, panel should show diagram and fuse sizes. Putting a larger fuse where it does not belong could result in melted wires.
Feb 16, 2010 | 2001 Honda Civic
My trunk won't lock?
What can happen is the hook ( I don't know the technical terms) on the body of the car slides down and the latch cannot properly engage it. Try loosening the hook and sliding it upward before tightening it down. This should allow the latch to properly catch the hook. This happened on my '91 Honda Civic and that's how I was able to fix it.
Mar 11, 2009 | 2001 Honda Civic
Cylinder head R and R
any competent repair shop or the dealer can give you this, make sure to use new bolts as these are most likley streach fasteners or tourqe to yeild and only work properly once -jeff
Jul 14, 2008 | 2001 Honda Civic
Speakers
Hi Trim God,
I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
Car Audio & Video Logo
108 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
