Question about Epson Stylus CX9400 Photo Printer
How do you fax from epson cx 9400
I tried faxing dialing with the phone itself and from the fax mode in the unit.
but neither of them worked...
anything i can try? thanks
    Scholar:
  • 134 Answers
Posted on Dec 12, 2008
Epson cx 9400
Defective cartridges or Generic cartridges. Change to Genuine Epson
Jan 17, 2014 | Epson Stylus CX4800 All-In-One InkJet...
Epson CX 9400 fax ink cartridges.
Hi i dont think the problem will be with the replacement pads as they wouldnt make them if they did not work your unit shouldnt be able to tell their not originals anyway.
The only reason people tend to buy originals is for the simple fact that you might get a poorer quality of print from the cheaper ones.
Up till now i have had no problem using the cheaper ones i havnt got exactly same unit as you but it sounds like they are not fitting in the unit properly.
Do you still have the ones you took out because if you do you could try putting them in again just to see if the unit exepts them ones or not this way you would eliminate problems with the unit itself.
Check that they are deffinately the same and make sure they are fitted properly if you are sure the unit is working then the problem is with the pads.
Make sure the ones you brought are exactly the same as the old ones the problem shouldnt be the brand as this is what they make the cheaper ones for whilst im waiting for your reply i will look for a manuall for your unit and tell you what i find out ok.
Let me know how you get on and i will try and assist you further ok........
Nov 30, 2007 | Canon I990 InkJet Photo Printer
Why is my fax machine not working? it reads no dial tone when i try sending a fax and i cant recieve either
make sure it is plugged in right in the back.try using a different phone jack in the house
Jul 12, 2009 | Epson Stylus NX300 All-In-One InkJet...
Can't fax out on my Epson Stylus CX5800X
Verizon is lying to you. Fax machines are analog devices.
Mar 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
My epson cx 9400 will not pull paper in when faxing thanks robertj463
Hi.. Have you tried cleaning the pickup roller?... after use the paper dust covers the roller and the paper slips... does the roller attempt to pickup the paper?.. is there some bits of paper stuck in the paper path?
Thanks
jim
Feb 18, 2009 | Office Equipment & Supplies
Epson Stylus CX9400 Photo Printer Logo
345 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
