My hp desktop screen is purple and not sure what to do i checked to make sure all the plugs are tight any ideas?
Have your boyfriend replace the video card and this will solve the issue.
Posted on Feb 17, 2009
    Genius:
  • 2,785 Answers
Plz check if there is any speaker,ups etc near the monitor,if yes then remove it. plz check the cable in the pc from monitor is there any bend pin, if yes then gently straighten it.if every thing fails then your monitor needs servicing
Posted on Aug 12, 2008
I turned my PC off and it never came back on, screen is black, any ideas?
Check all connections. Unplug them and plug them back in to make sure they are making connection. Some screens will have two cords plus plug it into electric outlet.
If your computer is running look for a switch on the monitor to turn it on.
Jun 08, 2015 | HP Pavilion All-in-One MS225
Hp touchsmart wont power up
It would seem that your power supply has failed. If you can open it you should check all of the connectors inside are tight. Make sure the power is off and the mains lead is unplugged from the wall.
Apr 20, 2013 | HP TouchSmart IQ504 PC Desktop
The code purple shows up on my computer hp desktop
The following error message opens after the PC is started after a recovery: Your system has detected a configuration error. Please call your Customer Care Center number, located in your Warranty and License information, for technical support. (Code Purple) contact hp tech support...meder's tv service Figure 1: Code Purple error c00372799.jpg
Aug 29, 2012 | HP Computers & Internet
I have HP P6243W desktop, will not boot up, after starting up, I get a blue screen, bought a restore disk set up from HP, but one the first disk it will run then I get a screen with a green check mark
The hard drive sounds like your problem, it might be a good idea to contact HP regarding the issue you are having to make sure the recovery discs are working properly.
Apr 07, 2012 | HP Computers & Internet
Went to hook up my pc and monitor and nothing shows on screen. Both lights are on but blk. screen, not sure if i hooked it up right.
Check the VGA connection,mostly on the monitor,and push it in and make sure its tightly fixed.
Also check power connections.
Hope this helps.Thanks!
Please rate this answer.
Oct 20, 2011 | HP Pavilion a705w PC Desktop
I have a LG flatron L246WHX monitor connected to my laptop, the colour on the screen suddenly is only showing green and purple colours. how do I get it back to normal, is the adjustment done on monitor or...
First, make sure that the cable you are using is plugged in tightly on both ends...if some of the pin connections get loose the colors can go a little funky.
If Cable is tight try another cable. This will eliminate the cable as your problem.
If another cable gives you the same result it is then usually either a problem with the video card in your computer or the monitor itself.
Try plugging the monitor into another computer if you can. If the monitor is OK on another computer, the problem is then probably the video card on your computer. If you have a desktop, it can be replaced usually, or another video card can be added and used if your video card is built into the motherboard.
If all of those fails, it is likely the monitor went bad. Check if it is under warranty to see if they will replace or repair. If not under warranty you may want to replace the monitor at that point.
Mar 23, 2011 | LG 22" FLATRON LCD Monitor
Configuration error on windows xp code purple
if its a code purple error on ur hp computer and its a blue screen error message then the issue is with the motherboard of your computer...and in this case nothing can be done.If your computer is only 4 to 5 years old or less than that call to HP they will replace your free of cost,HP's phone number is 18004746836
Nov 28, 2009 | HP Pavilion m7560n PC Desktop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
