Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dishwasher made clicking sound, then CL light, now nuthin'
While cycling, my dishwasher began making a soft clicking sound.  A few minutes later, it stopped, and CL was indicated.  I opened the door, and tried to restart the diswasher, and now I cannot get it to do anything.  When I press the cycled buttons, the lights indicate time elapsing, but there is no activity.  Help!  Thanks a lot!
  • nashella Aug 20, 2008
    Strangely enough, the dishwasher began to work again on its own.  For three days, I would look at it, try starting it up, and then finally just left it alone when I went out of town for the weekend.  When I came home, I pushed start and it started!  What do ya know?
I had a similar problem. After a $90 service call I was told it was the main electronic panel. The panel costs $180 and installation is $70. No Frigidaire is worth that. You, like I, should buy a new non-Frigidaire.
Posted on Aug 20, 2008
I am getting flashing lights on my dishwasher on/off light, 2nd and 4th light. Can someone help me interpret the error code and also suggest a solution please?
Hi, I had same problem with my Samsung dishwasher. Myine would start flashing about 45 seconds after the cycle started. Check under the sink for flexible hose that runs from the bottom of the dishwasher to the sink drain (mine actually runs into the disposal). Be sure there are no severe " kinks" or bends in the hose or anything that might impede the water flow. I straightened my hose as much as possible and "jiggled" it a bit and it began working ok. I haad the same problem again a few months later and jiggled/shook again and works ok since. There could be a partial blockage from food debris, etc. in the hose. Good luck.
Jun 28, 2015 | Dishwashers
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Apr 13, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
Started to get a clicking noise from the electic panel of my Frigidare PLDB998 dishwasher for a few loads and then it went dead. Its only a few years old
Did you ever find a solution? I have what sounds like the same problem. The time keeps ticking down but it flashes between CL and the time while the clicking sound is going, and it sometimes make a clunking sound while this is happening as well.
Sep 15, 2009 | Electrolux Frigidaire Professional Series...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Loud noise
Very loud squeaking sound, at the start of each cycle.
Jan 09, 2008 | Kenmore 16639 Built-in Dishwasher
Model 665/157874000/Undercounter Dishwasher
Hi First I would check to see if the water may have been turned almost off under the sink, it will be the Hot water side. if that don't help then check for something plugging the line. let me know what you find, or we can go deeper krazytech
Aug 30, 2007 | Kenmore 24 in. 15874 Built-in Dishwasher
Dishwasher keeps running and countdown stalls randomly.
Sounds like The settings have messed up it happened to mine a while back you need to do a hard reset of the dish washer mine was unplugging the thing then plugging back in 30 seconds later then holding the cycle button a few seconds and then power on again. Find your hard reset combination of what your make and model of the dishwasher is I hope this helps.
Jul 16, 2017 | Kenmore 15952 Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
287 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
