Have you tried running the installation in compatibilty mode?
uninstall the tuner driver and right click the install file and select Troubleshhot compatibilty. This will then ask if you want to use recommended settings or troubleshoot compatibility, select the second option. Then choose "ran in an earlier version" and "needs extra permissions" you will be asked which os it worked in previously so select xp or vista and click ok. You will then be presented with another box, click on the start program button, go through the installation process as normal, when you have finished click next on the box with the start program button, at the bottom click next and follow the prompts.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
