Question about Westinghouse Turbo Swirl 78145 Ceiling Fan
Westinghouse White M30-6B/1L turbo swirl ceiling fan
Glass globe broken. Where do I get a replacement?
5 Suggested Answers
  • 8404 Answers
SOURCE: cant find replacement glass for westinghouse turbo
As I understand it, yo need a new globe or shade for your Westinghouse Ceiling Fan. I;m happy to make this suggestion for you.
Home Depot and Lowes both carry a wide selecction of replacement parts for ceiling fans. You may find a direct replacement or something similar which will please you for your fan. You may find something at your local hardware store or electric supply house. There may be several FixYa.com advertisers which can provide you with the parts you require.
Thank you for posting your question on FixYa.com and I hope you found some value in these comments
Posted on Nov 07, 2009
FixinFax
  • 3085 Answers
SOURCE: i have a Westinghouse Turbo Swirl 78144 ceiling
Turn the light cover counter-clockwise, it just unscrews like a light bulb.
Posted on Nov 16, 2009
heatman101
  • 43501 Answers
SOURCE: I am looking for a replacement glass globe for my
Lowes and Home Depot each have many glass replacement globes that will fit most any ceiling fan light assembly.
You will need to know the diameter of the glass where it goes into the metal part of the light and the depth that the globe needs to be to clear the lgiht bulb.
Heatman101
Posted on Feb 28, 2010
  • 4 Answers
SOURCE: Chaning a lightbulb on a Turbo Swirl Ceiling Fan
The dome just pulls off.
Posted on Mar 15, 2010
caroldon
  • 17129 Answers
SOURCE: I broke the glass of
The only way is to get in touch with Westinghouse , contact them through their website and post your query or take the details of the office near to your area, call and confirm.<br /> please on the site :http://www.westinghouselighting.com/<br /> hope I could help
Posted on Aug 29, 2010
How do you change the lightbulb on the turbo ceilng fan. can't see how the globe comes off
there are usually screws that are around the top of the globe or you have to twist the globe gently.
Dec 31, 2010 | Westinghouse Turbo Swirl 78145 Ceiling Fan
How to chance light bulb
On that model fan the glass globe should unscrew to get to the bulbs if not they are replaced by going between the blades & the motor to the space in between.
Oct 02, 2010 | Westinghouse 78144 Turbo Swirl™ Brushed...
I broke the glass of the Westinghouse Turbo Swirl 78145 ceiling fan. Could you tell me where to get the remplacement? Pedro Maglione
Aug 28, 2010 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Cant find replacement glass for westinghouse turbo swirl 78144
Nov 07, 2009 | Westinghouse Turbo Swirl 78144 Ceiling Fan
Bulb replacement 0 how do you get the glass cover off?
Les:
The globe is held on by three metal tension clips holding the globe to the base. To remove the globe, you need to pull down on the globe gently but firmly. Try pulling down on one side and then the other, sort of "wiggling" the globe off. Getting the globe back on can be a bit of a challenge, calling for you to get all three clips aligned in place before pushing the globe back up. A little patience and the job will go smoothly.
Hope this helps. If it does, please leave feedback! That is the only way I know if I am being of assistance or just wasting my time.
Oct 10, 2009 | Westinghouse Turbo Swirl 78145 Ceiling Fan
I can't remove the globe to replace bulb in the ceiling fan. I removed the 3 screws but I can't tilt the globe.
My fan has no screws. You simply twist and tug the globe (firmly but easily) and find that it is held on by three "tension clips" that hold the thing in place.
If you are nervous, have someone else get on the other side of the ladder and hold the fan steady while you twist/tug the globe with two hands.
I did it by myself but I would have liked another pair of hands holding the fan steady while I gently but firmly tugged at the globe.
Jan 19, 2009 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Westinghouse Turbo Swirl 78145 Ceiling Fan Logo
431 people viewed this question
Top Westinghouse Dryers Experts
Richard Roth
Richard Roth
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
