Question about Panasonic Heating & Cooling
Hi i have a cs-w24ekr air conditioner. The problem is it blow's cold air when set to heat even at 28degrees.
You have pressed the mode button on remote until it has said heat aswell? becasue 28 degrees in cool mode will still seem cold unless the mode is also set to heat.
Posted on Sep 21, 2008
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
The blower starts before its warm and it blows cold air for about 30 sec when its shutting down .
When any unit 1st come's on, you'll always have some cold air that's in the ducts that will blow out before you get warm air. If your duct work is uninsulated in a cold basement or crawl space then it will be even more noticeable. When the unit is heating from the Heat Pump mode, it takes a little longer for the gases to get warm enough so you'll fell heat. When it gets cold enough for the unit to switch from heat pump to the gas or electric heat source, you'll get warm air faster. If you have gas heat, some Thermostats have an anticipator setting for the gas valve. If it's set wrong it will effect the on/off cycle of the gas valve.
All duct work in non heated and a/c spaces, including inside walls,above dropped ceilings, in attics and crawl spaces, must be sealed & taped at the seams and joints and then insulated and taped.
Most new construction has solved that problem with insulated duct board, flexible insulated supply's and special tape.
Dec 12, 2013 | Rheem 13PJL30A01-RHLLHM3617JA 2.5 Ton 14...
Panasonic CS-A12DKD Air conditioner does not
This could be an inoperative reversing valve or bad reversing valve solenoid coil.
Oct 31, 2013 | Panasonic Heating & Cooling
LG LS-D2461HS air con on turn on just blows air out. no heat or cod air at all even when temperature setting increased to 30 degree for cold air.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 27, 2011 | LG Heating & Cooling
Hi i have a problem with my air con its on heat but it blows cold air and freezes up ???
Is there a dial control to change the heat setting from 1 to 10? Even if you have it on heat, if you turn it to the lowest setting (which is to cool) it would still blow cold air. Turn it up to ten - all the way and see if that solves your problem.
Also check to see if the button that says heat or air is on upside down. Pull it off and turn it over if thats the case.
Jun 18, 2011 | Heating & Cooling
HEIL A/C PACKAGE UNIT ELECTRIC HEAT BLOW COLD ON HEAT AND COLD
Air Conditioner Trouble - Review the Possibilities
heatman101
Jan 05, 2011 | Heating & Cooling
Arcoaire NFCX 3600C1 heat pump - blows cold air even with emergency heat on
Check the O/B setting on the thermostat and equipment to insure the reversing valve is energized during the proper heat/ cool cycle. Also check the thermostat wireing to insure electric heat element is set up.
Feb 01, 2010 | Heating & Cooling
Heating & Cooling Logo
179 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
