Question about Apple iPod MA446LL/A MP3 Player
Dead my 30 gig does not do anything but give screen flicker and a low bussing sound when I plug it in
  • jilala Nov 18, 2008
    I used my ipod (80G 3rd Gen) yesterday, was working fine (although battery was very low). Would not turn on this morning, I assumed the battery was dead - but although it charged for several hours it's still dead. When I try to turn it on or reset it (with centre and menu buttons) the screen flashes blue momentarily but that's all.
    My laptop isn't detecting it. It's not making much of an effort to turn on - I don't hear the usual grindings and clickings of an ipod in pain. Is it power failure? The warranty has expired. I bought it online from apple. Where should I take it if all else fails?
    Thanks,
    -V
  • Anonymous Nov 23, 2008
    my 30 gig does not do anything.when i plug it in to charge it doesnt charge.
    Scholar:
  • 92 Answers
Hi all, before trying any thing else try these steps out:
1 By 1:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
or
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    1. Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
    1. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
    2. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    1. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
    1. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
    2. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
    or
    1. Before placing the iPod into disk mode, you should verify that it is charged.
    2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
    3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
    4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
    5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
    If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
    If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
    or
    1. Open the Control Panel.
    2. Double click on Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
    3. Double click on Computer Management.
    4. In the left column, click on Disk Management.
    5. Locate the iPod and right click on it, then click Change Drive Letter and Paths.
    6. Click the Change button.
    7. Use the drop-down menu to select a new drive letter. Note: Make sure to choose a new drive letter that is not already assigned to a network drive. The drop-down menu will display all available letters that are not assigned to a physical drive. Drive letters that are assigned to a network volume will still be listed here. It is also a good idea to assign a drive letter other than a, b, c, or d, as these letters are usually reserved for other system drives.
    8. Click OK.
    9. Click Yes on the confirmation dialog.
    10. Close the Computer Management window.
    11. Restart your computer.
    This should resolve your issue's guys
    Posted on Feb 04, 2009
    My silver ipod nano 8 gig is stuck on the sync screen and wont do anything else can u please help or give me assistance???
    Press and hold the MENU and select/center button at the same time. This should restart it and unfreeze the screen for ya.
    Jan 01, 2010 | Apple iPod nano
    Tip
    Reset 30 gig zune
    if your zune locks up it is more than likely a bad music or sound file. the best way to unfreeze your 30 gig zune don't laugh it works by putting your zune in the freezer to clear memory and batery.
    step1. put it in the freezer for 1 hr
    step 2. remove from freezer and allow to come to room temp
    step3. plug in and recharge fully
    step 5. reload music on zune
    on Feb 18, 2010 | Audio Players & Recorders
    I have a 120 gig classic ipod, and i have 3 white
    It is probably a short in the connector inside the unit going from the screen to the circuit board. You can replace the screen yourself, just have to do some google searching. Also, if you wanted to connect your Ipod to a TV, you can plug an RCA cable into the sound port. You have to have the cable that has three prongs on one end (yellow for video, red & white for sound), the other end of this cable is a 3.5" (headphone) audio plug. Classic iPods export video data from the sound headphone jack!
    Jul 05, 2009 | Apple iPod nano
    IPod Nano (1st gen) battery won't charge or show up on iTunes
    Sounds like the battery may be bad. See about getting it to a shop for replacement. Also if you have an apple store in your area they will consult with you for free on this unit.
    Mar 19, 2009 | Apple Audio Players & Recorders
    My 30 gig Ipod video kills the battery. my son gave it to me and I didn't use it for about a year and when I tried it was dead. plug it in & charge then dead in approx 30 mins EVEN IF i DON'T TURN IT ON! I...
    this sounds like a hardware problem it might not be the battery but maybe something else it could be th hard drive it probably doesnt turn off, check the apple store ask the people there.
    hope this helps, Cameron
    Mar 11, 2009 | Apple iPod MA446LL/A MP3 Player
    Ipod touch battery
    have you tried a factory reset (in itunes, while your ipod is plugged in, click on the ipod touch icon to the left, then go to general, and go to "reset ipod to factory settings" or something similar)...this will only erase what is on your ipod...it won't affect your itunes. also, if you already tried reseting it and still not working...you could get the 2.0 firmware update...it's about $10 dollars to upgrade to that though (i'm not a fan of apple...especially not now) you can get the upgrade directly from the apple website here ....so try those solutions. also make sure you have the correct drivers installed..which would be ..and if those don't work, i would call apple and talk to them about that issue..if it is still under warranty, you should be fine to have it replaced (or if you bought it somewhat recently) and if not...you'll have to sharpen your voice to a almost threatening tone and apple will most likely give in and either replace it or give you money.. ((i called them when i got an ipod video 30 gig, and 1 week later they released the 60 gig for the same price as the 30....so i called them and yelled at them alittle bit...they gave me $50))....i hope this has helped....oh and do you have a mac or windows? is it 1st generation ipod touch or 2nd generation (very thin is 2nd generation)? also make sure the drivers are up to date (if your computer is connected to the internet, open itunes and plug in your ipod, it should tell you if you need new drivers...if not, you're good)
    Dec 21, 2008 | Apple iPod touch
    80 gig video i pod screen locked up
    tryr restarting it Hold down the middle and the top button for 30 seconds
    Jul 08, 2008 | Apple iPod MA446LL/A MP3 Player
    30 gig Ipod wont come on
    Hello HBB-Wildman,
    It sounds like the battery in the iPod may have failed. The internal battery pack in the iPod is designed to last a long time but will eventually fail and require replacement.
    I would suggest either taking the unit into your local Apple Store or following the procedure on the iPod support page to get service on the unit.
    Best Regards,
    Ken
    "Go Ahead. Use Us."
    Jul 03, 2008 | Apple iPod MA446LL/A MP3 Player
    Black Screen, Not turning on but charges?
    If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
    Q. How to reset Zen v +
    http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
    Feb 06, 2008 | Creative Labs ZEN V Plus MP3 Player
    Apple iPod MA446LL/A MP3 Player Logo
    67 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Jazz Boyce
    Jazz Boyce
    Level 1 Expert
    mac colar
    Sean Cole
    Sean Cole
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
