Question about GE Profile J2S968 Dual Fuel (Electric and Gas) Kitchen Range
Ge range j2s938 glass top installation
I wonder if you can help me by given me tips on how to replace the glass top of my range...the model is J2S968SOH4SS..I broke one of the corners want to replace it..
thx
ma
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Replacement of glass top
Check your warranty in the back of your use and care book. If the unit was manufactured prior to 1/1/06 it may have a five year part (not labor) warranty as long as you did not physically abuse it. The glass top comes as an assembled top (glass, the black seal, and the metal frame holding it)
Disconnect power. remove screws under the front edge of cook top. lift cook top and remove crossbars holding burners up against glass top. Unhook cook top / frame assemble. Install new top in reverse order.
Posted on Aug 31, 2008
appldoctom
  • 311 Answers
SOURCE: replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Posted on Jan 05, 2009
  • 10865 Answers
SOURCE: GE Spectra model JBP78COB1CC
ok Jim - to answer your first question, you can still use the oven but it will be less efficient and will probably not operate at the temperature you set it at.
Yes you can replace the glass yourself. ?You will need the right glass for your model of stove and the installation kit to go with it.
You can purchase these at a website such as www.repairclinic.com
Posted on Feb 18, 2009
Testimonial: "Thank you very much. Now my next step is to actually order the glass and perform the repair...I may be coming back soon! :-)"
MNTECH
  • 1543 Answers
SOURCE: GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Posted on Jul 01, 2009
Looking for Glass-Ceramic Cooktop for GE Range, Model: GRSR3920ZWW-3
I am sorry but we have no parts or anyway to refrence them here at Fixya. Contact GE customer service for parts.
Aug 31, 2012 | GE Kitchen Ranges
Glass on door broke. Is it easy to replace?
Most of the time the replacement is really not that hard...here is a tip that I wrote about that...
Range/Stove/ Oven Door Glass Replacement
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
The very bottom link on this tip will help you with getting the part online...
heatman101
May 11, 2010 | GE JBS55 Electric Kitchen Range
Broken Glass on Cooktop
Ouch. The glass top does have to be replaced but I just ran the partial model number on your range and if you're at the comp. I hope you are sitting down. Replacing it not bad. Purchasing tho is rediculous. Retail suggested price just for the top is 600.00. Rediculous pricing but GE is like that sometimes. Sorry but repairing the glass is not possible and getting it from a glass shop isn't either. Sorry for the not so good news. Rick
Mar 01, 2010 | GE JSP57 Electric Kitchen Range
I need to replace a cracked glass top (GE Profile Slide In... where do I find my oven model number and part number
If you dont see it around the door or inside the stove you'll have to raise the top and it should be there somewhere. The part number for the glass top I can get for you if I have the model number
Sep 08, 2009 | GE Profile 30" Self-Cleaning Slide-In...
Glass top on range is broken.
pull bottom panel out look on stove middle just below oven door
thumbs up
Aug 17, 2009 | GE Spectra JBP78 Electric Kitchen Range
Feb 02, 2009 | GE Spectra JBP78 Electric Kitchen Range
Glass top on GE stove broken
Hi Sara,
I work for an Appliance company and although we don't carry G.E. I believe you can get the top replaced. My last glass top was a GE and they told me (Sears) if it was damaged, it could be replaced. It costs about half of the original range. Not exactly what you want to hear. I was told by them " it is a costly repair." I would look up GE online and see if there is an 800 service or trouble shooting number. Based on model they would be able to give you a suggestion as to which way is cheaper. I hope this helps. Good Luck.
Dec 10, 2008 | Frigidaire FEF366 Electric Kitchen Range
CRACKED GLASS GE - JB968
1 Unplug cooktop or disconnect power.
2. Remove the cooktop from its mounting
location, (see “Installation Instructions” in
Section 2). Position the cooktop so that
you can access the bracket screws below
the cooktop glass
3. Remove the fourteen flat-head screws
from the front, rear, and side ceramic glass
brackets.
4. Remove the two small side brackets from
the cooktop base.
5. Lift and remove the ceramic glass from the
Oct 13, 2008 | GE Profile JB968 Electric Kitchen Range
I BOUGHT A GE GLASS TOP STOVE IN FEB. 2008. I WAS WONDERING IF THIS MODEL JBP62DMWW, IF I CAN PRESSURE COOK ON IT. CAN YOU HELP ME? VERNA
yes you can but consult your owners manuel as certian type of cook ware will scratch the top but if your careful and not move the cooker around it wont scratch but the cook top is strong enough to support the cooker
Jul 10, 2008 | GE Kitchen Ranges
GE Profile J2S968 Dual Fuel (Electric and Gas) Kitchen Range Logo
121 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
