Question about Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer
Kenmore washer won't come on
Washer was working great. when put in laundry for next load, the washer would not come on. we checked the power outlet and there is power there. we unplugged the washer and plugged it back in, but still no results. what do you suggest?
I have the same problem that started today. No idea.
Posted on Aug 31, 2008
2 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: kenmore washer won't come on
HI sorry the chat just quit on me i was not done. i would check the lid switch. the little piece thats on the lid goes into the top and hits the lid switch. look at that
Posted on Oct 13, 2008
Why does laundry center have no power?
Kenmore washer 40272 has no power. Unplug and wait a ...
www.shopyourway.com > Manage My Life > Questions
I have a Kenmore 40272 front load washer. ... I remove plug from outlet, wait, then plug back in. ... Do you have the washer plugged in to an outlet or is an extension cord being used?
Nov 06, 2015 | Kenmore Washing Machines
Plugein but no power
Check power outlet is working by trying another appliance, if it is ok you will need to either get a qualified engineer to trace the voltage through to see where it's failing. If the power outlet and flex are ok next step is the on/ off switch, and any fuses/safety cut outs . Alternatively if you disconnect it you can check continuity with a test meter . Caution high voltages when connected to the outlet.
Apr 18, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
see this causes and fix it. God bless you
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
If the washer won't start the line fuse might have blown.
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Super Capacity Washer Not Working
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Oct 13, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washer just stopped
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, check/replace lid switch. Also try tightening the lid hinge screws on the left side. if these screws come loose, the machine will not operate
Jun 14, 2008 | Kenmore 24642 Top Load Washer
Kenmore 4.5 cu. ft. Oasis Canyon Top Load Washer Logo
264 people viewed this question
Sal De
fordexpert
Robert Rankin
