Question about Samsung SGH-D900 Cellular Phone
Samsung d600 bluetooth rarely works
I have a samsung d600 and when i search for other bluetooth devices or try and pair it with my headset it hardly finds them,and im sure all my settings etc are ok.if I try and scan 3-4 bluetooth devices in a room that i know are on and not hidden it will maybe pick up 1 device every few searches d then say no devices the rest of the time.it is the same when my friends try and search for my phone.it will come up every now and again.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Hi there, it looks to me as if your blue-tooth module might have a dry joint, this is easily fixed by a repair centre, they will be using hot air to re-solder the module. This gives you a 80% repair.
Posted on Aug 12, 2008
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
I have bluetooth device (wireless headset) and i want to pair it with my Samsung B5722... Can you give me detail instructions? Is my Samsung B5722, capable of pairing to bluetooth wireless headset?
yes, your samsung is capable of pairing to bluetooth wireless headset. all you have to to is go to music player, go to options and select play with bluetooth devices or search for visible bluetooth devices.
May 11, 2011 | Cell Phones
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a kyocera bluetooth and I lost the code to pair it with my phone how can I find it? 739G-001 is on the headset. I can pair it with my phone if I can find the passkey I have a samsung phone. The...
I just paired one that sounds like yours with my phone and don't remember needing a pass code, but try 0000
From the quick start guide at:
http://www.kyocera-wireless.com/support/pdf/bluetooth-kyo105-quick-start-guide.pdf
PAIRING THE HEADSET WITH YOUR CELL PHONE
Note: Ensure your headset is powered off, and your cell phone is powered on.
a. Press and hold the Multi Function Button for 6 seconds until the LED Indicator flashes red and blue. A tone will sound indicating your headset is in pairing mode.
b. Activate the Bluetooth connection from your cell phone. Execute the search function to search for Bluetooth devices. When the search completes, a list of supported devices will be displayed on your cell phone screen.
Note: The headset will not be detected unless first placed in
pairing mode.
c. To start the pairing process, select KYO105 from the device list.
d. When prompted select 0000 as the passkey.
Jul 18, 2010 | Samsung Lands Phones
Cant pair my wep 500 with my phone
passcode = 0000 (4 zeros) USER GUIDE
The first time you turn on the headset it will enter "Pairing" mode. In this mode you can connect your headset with your phone or other Bluetooth enabled device. If you have already connected one device to the headset, you can enter Pairing mode by holding the multi-function button turns solid blue.
Once in pairing mode, set your phone or other Bluetooth enabled device to search for the headset. While each device is different, the setting is often found in a "Settings" or "Bluetooth" menu and the "Search" or "Discover" Bluetooth devices option. On the list of discovered devices, choose "Samsung WEP500" and select "Yes" or "Ok" to connect to the device. When asked for the passkey, enter 0000.
Feb 05, 2010 | Samsung WEP500 Wireless Headset
Pairing the Samsung WEP 210 headset to my Samsung Soul phone
Pairing Instructions
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
Ensure that the headset is off (see Turning the headset on/off).
Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a Setup, Connect, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices.
Your phone will find the Samsung WEP210 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
Aug 21, 2017 | Samsung Bluetooth Headset WEP-210 B2700...
J can't use the bluetooth headset wep210
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
How do i pair my H700 MOTORAL bluetooth to my verizon cell phone?
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Searching for the headset on the Blackberry
4) The Blackberry should search for any available Bluetooth devices and display what was found
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Connecting bluetooth headset wep300 to D600
before u perform a search on the phone, switch off the bletooth headset.
Now (bt headset still off) hold on the power button of the bt headset (approx 10 sec) til the blinking light turns to a continuously lit light(the light will not blink but will just remain on).
Perform the search on the phone and connect to the headset. The pin should be 1234.
Dec 02, 2007 | Samsung SGH-D600 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
63 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
