Wd 52525 during power up the lamp red light comes on even after replacing lamp with new and good lamp?
  • frankiemelis Oct 30, 2008
    I have the same problem I was watching tv and then the lamp light went red now my tv won't stay on I did get a code 34 does that mean I have to change the lamp light and if so where is it on the tv.
    thanks a million
    Mel
  • 8,617 Answers
Press the menu and input/device on the set both in together and hold for 5 seconds to see if the led will blink a two didgit blink code such as 3 blinks a pause then four blinks for a 34 code. Then let me know. respond to this same post when replying.
Posted on Aug 12, 2008
My Mitsu 52525 lamp indicator went solid red. I
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
Mar 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Red blinking light
If the red lights comes on and stays on, you will need to replace the lamp. However, if the red light blinks repeatedly, your internal motherboard was either fried during a recent power surge, or the circut board will need recalibrating. In short, you will need to contact a cert. technician to re-initialize your set. It may be more cost-efficient to purchase new flat-screen plasma set. Good luck with your investment.
Jan 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD 52525
HELLO . IT SOUND'S LIKE YOU NEED TO REPLACE THE BALLEST .!! AND THAT SHOULD FIX IT.!!! "GOOD LUCK"
Aug 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Replaced the lamp, 8 days later it`s out again.
You Have bad cap's on you power supply board causing the
5 volt line to go low. Call a service provider.
Oct 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No picture
Lamps have been known to burn out the power supply to the DM assembly. If there is no visible damage to the lamp, your problem may be the power supply or the board. Good luck.
Oct 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
