Question about Refrigerators
MOTHERBOARD SHOT ON GE REFRIGERATOR/ TOP-FREEZER
Mine too.
Paid $300 to the GE tech to replace WR55X10552 is the Mother Board number
It took him 5 minutes to figure it out\change it and he left the 6th minute
cannot believe they charge $50 a minute
What a rippoff
This happened in the 6 and half years of the ownership of the Refrigerator
Posted on Apr 22, 2009
  • 3368 Answers
SOURCE: GE top freezer refrigerator fan rattles constantly
It is mounted properly, it is probably a bad bearing in the fan motor and/or the blade is loose on the shaft. Replace the motor.
Good Luck,
Gil
Posted on Mar 01, 2010
SOURCE: top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Posted on Apr 03, 2010
  • 66 Answers
SOURCE: @15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
Posted on May 17, 2010
heatman101
  • 43501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 28, 2010
mreid542
  • 166 Answers
SOURCE: GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Posted on Jul 12, 2010
Need motherboard info for pfsf6pkxabb
Not a solution but if you need a motherboard I recommend going to GE. I purchased one & it was cheaper than Amazon or anyplace else I could find.
Mar 15, 2014 | GE Profile Arctica Stainless Steel Top...
GE 18.0 Cu. Ft. CleanSteel Top-Freezer Refrigerator - GTL18JCPWRBS Water isn't going to the ice maker even though the water supply is on
Locate and replace the water filter. It should be covered in the owners manual. If that is not the problem, then the solenoid that turns on the water supply is shot, at which point you are probably better off just buying a replacement ice maker.
Oct 02, 2013 | GE GTL17JBSBS 28" 16.6 Cu. Ft. Top-Freezer...
The compressor does not kick on , but the fan keeps blowing
This sounds like motherboard problem. Try unplug your box for 3 mins. Then plug back in. This will reboot the motherboard. If not you may need to replaced it. Not cheap 250-300 dollars from GE. I hope this helps.
Aug 23, 2011 | GE GTS22WCP Top Freezer Refrigerator
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
heatman101
Mar 30, 2010 | GE GTS22KBP Top Freezer Refrigerator
Original motherboard
Hi, When i change motherboard that got fried I change also the Temperture sensor Number: WR55X10087
it is under the cover on the right side
Jan 07, 2010 | GE PTS25LHP Top Freezer Refrigerator
GE Refrigerator Not Cooling (TFX27ZPBGWW)
The unit isnt defrosting hence the ice on the back panel. Either your bimetal thermostat is open or the heating element is shot. Most GEs they come together so happy hunting. Those parts are behind the frosting panel
May 28, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Clicking noise
your repairman is correct . common problem with this GE
Mar 05, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Refrigerator stopped cooling
I had the same problem. Replaced the damper switch and the motherboard. Then noticed the freezer has frosted over behind the panel in the freezer. Defrosted the freezer and all was working again. The same problem came back about 3 months later. This time the problem was diagnosed as the heater has gone bad in the freezer. Now waiting to have this replaced.
Jun 18, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
1,530 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
