Question about Apex Digital Digitrex DSC-3000 Digital Camera
The word "error" appears in the middle of the LCD
I turn on the camera and I see the word "error" in the center. I cannot take pictures as a result of this.The night before I was printing pictures from the PC. I tried troubleshooting the problem, but with no luck.
Cassy
  • Hammish22 Aug 12, 2008
    Still Need help with the problem!
I still have the problem with the word error still present in the middle og the LCD.
I tried to go on and print some pictures in order to turn it off more carefully and I cannot do it.
Posted on Aug 12, 2008
No picture appear on screen..and it says picture error
Try and see if you can play back old pictures that were taken on with this camera. if so the LCD is good and the suspect seems the CCD - imaging device - or the control circuit.
If there is no picture seen then the LCD is a suspect.
To check the CCD and control board it is ideal to take support from service center specially when estimate and spares are needed.
Jul 21, 2011 | Vivitar ViviCam 8400 Digital Camera
I have a blurry image distortion in the center of the picture only- everything else looks fine- a solution to my problem?
is the central of lcd divice bumped ?
1-are your lcd device show the correct image without any blur before taking the image ?
2- or this blur shown after taking the picture ?
for the first : your device lens should be clean through inner side.
for the second : the lcd should be checked , since the center of lcd may be bumped.
please let me know your checking result.
good luck
gorbesia
Jun 14, 2011 | Nikon Coolpix 4600 Digital Camera
My digital camera screen will not turn on
This is a problem with the internal lcd components or the lcd screen itself. Have you downloaded the pictures off the camera? Your options are repair or replacement. Follow this link for repair through sony:
https://eservice.sony.com/webrma/web/index.do
Sep 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera turns on, lens goes out, but it is black, see nothing through it or on lcd screen (yes, cover is off). There is no error messages, still takes pictures but just black. Can view previous pictures on...
It coud be a very common IRIS/Shutter stuck problem...this has been reported on lot of S3 IS & S2 IS cameras... just search for this on web and you'll find a temporary solution also (related to taking battery out in the middle of taking picture during a long exposure (15" in Tv mode), but for more permanent fix you need take it back to Canon service center
Aug 03, 2009 | Canon PowerShot S3 IS Digital Camera
Lcd screen has black spot inside, outside fine, takes pictures
you should replace the lcd screen from an authorized service center. or you can buy the lcd screen alone from ebay and find someone to replace it .remember
never open the camera unless you know very well how to replace it.thanks for using fixya. please dont forget to rate my solution
Jun 01, 2009 | Fuji FinePix J10 Digital Camera
Picture result is too bright when taken on outdoor condition
change the lcd setting by pressing menu then right arrow. go down to the sun picture and then click the left arrow and put it in the middle. i hope this helps.
Apr 25, 2009 | Canon PowerShot A420 Digital Camera
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the LCD monitor.
Please follow the procedure below: 1. While the message is displayed, press the center of the controller. 2. The LCD monitor and data panel will turn off . 3. Turn the Main Switch to OFF and remove the CompactFlash card from the camera. 4. If "No Card " message appears at next time the camera is activated in the recording mode, the camera and CompactFlash card are OK. 5. In case that "Card Error. OK" appears again, the CompactFlash card may be faulty. Use other card.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Blurry Pictures
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE (Flower Icon) for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Using MACRO MODE improperly will result in poor focus. 4. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 15, 2005 | Toshiba PDR-M25 Digital Camera
Blurry Pictures
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Apex Digital Digitrex DSC-3000 Digital Camera Logo
74 people viewed this question
Top Apex Digital Cameras Experts
Mohammad Abumuailek
Mohammad Abumuailek
Steve
Tony Parsons
Tony Parsons
Are you an Apex Digital Camera Expert? Answer questions, earn points and help others
