Dryers Logo
Anonymous Posted on May 05, 2011
Gas dryer, does not get hot. - Maytag Dryers
Dan Webster
Level 3:
  • Maytag Master 8,221 Answers
  • Posted on May 05, 2011
Dan Webster
Maytag Master
Level 3:
Answers
8221
Questions
5
Helped
2379121
Points
25840
First look for air restrictions which would cause overheating and remedy that. Then hunt down these duct fuses and check them for continuity. The gas dyer fuse kills only the circuit to the gas valve assembly so if it or the control klixon next to it is open then no power can get to the gas assembly. The gass assembly consists of a flame sensor , an ignitor, and a pair of solenoids. All are powered together in a complex circuit intentionally so that the power is first diverted to the ignitor which will nt allow the solenoid coils to do their job because their is not enough juice to work the ignitor and them coils. So the flame sensor detects the heat coming off the ignitor and a bi-metal inside bends and kills power to that ignitor. With the energy freed up them coils yank open the gas valve and the gas flows outgas dryer, does not get - themobilian_2303.jpgbr />themobilian_2305.jpgthemobilian_2304.jpg
If the ignitor comes on and the flame sensor shuts it down but no gas comes out or gas comes out on first try but fails to fire off again then them solenoid coils need to be replaced. More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May tag gas dryer don't get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Frigidaire AGQB6400FS not hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
My gas dryer is not getting hot i tried cleaning vent and lint trap
heatman101
Dryer does not get hot
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
MY GAS MAYTAG DRYER DOES GET HOT BUT THERE IS A SMELL WITH THE HEAT AND ALSO NOT GET AS HOT AS IT USE TO
heatman101
THE DRYER IS NOT GETTING HOT
Hi
Please check the following things that could stop a gas dryer from heating:- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
2answers
My dryer will not get hot
My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
2answers
Dryer gas
heatman101
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
