PC1060 canon copier
I have a paper jam -- normally no problem - manual advises jams on right side of machine but not for left -- where the copy comes out -- scrunched up tight -- tried tugging - ripped - and I can't get the other 1/2 out -- when trying to use tweezers the paper rolls back in to copier. There are no leavers or buttons to open to remove. Do you have any suggestions
Also Canon advised take to repair shop -- I'm new to this area -- no Canon in Kitchener/Waterloo - I cannot carry -- do you know of a repairman that will come here from the area.
Thanks
Nancy
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
In your case you have to remove the fuser
I will try to guide you, most of the models are the same.
1-turn off machine and unplug
2-open the side door, you already know where the paper is it's most likely rolled up on a hot long roller, this is the fuser unit
3-with a phillips scredriver(star) remove 2-4 screws that hold the unit, it will have a plug most likely on the right hand side unplug
4-unit should slide out (unless there is a cover holding it
5- you can now see and work on the unit turning the gear by hand to remove the paper.
6-reverse the steps
Posted on Aug 12, 2008
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Canon ir2016 jams papers under registration clutch. the clutch runs on power up but does not run when copig or printing help
This seems to be a common problem for the Canon ir 20 xx series machines. The problem is having machine indicating paper jams on the left hand side of the machine. When you open the left cover you do sometimes find paper stuck on entering the fuser unit. The main problem, and loads of these machines with these problems have been fixed, are the half moon pickup rollers! Clean the pickup rollers or even better, replace them and you will get the machine working 100%!! To confirm this try copying from the machine using the manual feed tray. You will never get a paper jam. This fault is due to incorrect pickup resulting in timing problem and thus getting paper jams! Good luck!
Mar 10, 2014 | Office Equipment & Supplies
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
May 20, 2010 | Canon imageRUNNER 2000 Copier
Hello, we have a Canoncopier pc1060 with a paper jam. We need to be able to get the top off to remove the jam. we thought we got it all out from the side but we can hear a piece of paper in there when the...
I'm not sure if you mean the adf or the top half of the copier??? The adf comes off, it's tricky, there are pins that hold it in. As for the top part of the copier, why would you? I did it only once, will never do it again. I think you problem is in the fuser unit. If so, it comes out of the left side by the exit tray. Before I go any further, have you seen any small pieces of thin blackish grey plastic. If so, you need a new fuser unit or fusing film. I would not go any further if that is the problem. Without it to put right back in, you will forget how to put it back in... Good Luck
May 05, 2010 | Canon PC-1060 Black and White Copier
Paper jammed as it was coming out
First, I prayed for help since I was using the copier when it jammed and then I very carefully pulled a small bit of paper on one side being certain not to tear it, then the other side. After about 30 minutes by using a eyeglass screw driver to help the paper come out, it pulled out and looked like an accordion. I put the toner back in and it worked fine. After reading the reviews, we won't be making double sided copies on this machine.
Thanks for your assistance.
Apr 12, 2009 | Canon PC-1080F Plain Paper Laser Fax
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
Paper jam
make sure that the exit sensor is realese down.generaly u ca check the sensors not to have pull out
Nov 11, 2008 | Canon Office Equipment & Supplies
Jammed paper
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Jun 07, 2008 | Canon ImageClass D880 Copier
187 people viewed this question
jasbo
jasbo
