Question about OKI C5400 Laser Printer
OKI C5400 & Vista
I have a OKI C5400 with a Vista operating system. My problem is: the print quality isn't a good through Vista as it was when I had it on my old XP system. I have the up to date driver (the only one that OKI offers for this model) I have tried many different settings within the setup dialog for the printer with no luck. The pictures I print are grainy - course, they don't print fine, it is like I'm using a low dpi printer setting. Is there any specific settings I can try, any help would be great. Thanks.
    President:
  • 1,653 Answers
Assuming that you are using the same paper and have not changed any of the consumables you should do the following:
1. Clean LED head with lens cleaner or soft tissue.
  1. Remove the toner cartridge and give it a few shakes then reinstall it.
  2. The Toner Could be low so Change toner cartridge.
4. Make sure that the paper is not damp as this will cause fading and poor quality printing and images.
  1. The image drum may have been light contaminated so remove it from the printer and store it in a totally dark place for several hours then reinstall it.
  2. If the image drum is dirty then wipe it very gently with soft tissues, being careful not to scratch it.
  3. Open the top cover and check to be sure that each toner cartridge is fully seated and that each toner cartridge lock lever is pushed all the way back.
  4. Press the top cover release latch and open, then close, the cover.
  5. Check MEDIA MENUTRAY1 MEDIA TYPE and set as required. Do the same for TRAY2 and MPT.
  6. Check MEDIA MENUTRAY1 MEDIA WEIGHT and set as required. Do the same for TRAY2 and MPT.
  7. Possibly set the value of media weight in the menu to the next heaviest one.
  8. Check PRINT MENURESOLUTION setting and set to 600 x 1200DPI
  9. Check PRINT MENUTONER SAVE MODE and make sure this is OFF
  10. Check PRINT MENU – MONO PRINT SPEED and make sure this is set to MIXED SPEED
Posted on Sep 11, 2009
OKI c5400 error 0x000000aa port comfig
Hi Fixya
The error you mentioned is related to the Microsoft operating system.
Please find the below article for your reference
http://winwiki.org/port-configuration-error-0x000000aa/
Hope it will solve your issue.
BR
Ganesh
Nov 21, 2014 | OKI C5400 Laser Printer
How to fix error 491: Tray Empty on Oki c5400
printer oki b411dn put out of the balcony, unsatisfied by his work, too many error codes, to lost time, to failed
Feb 27, 2012 | OKI C5400 Laser Printer
Not printing in color, how do I reset?
It is unlikely to be the printer (not impossible but unlikely) have you checked the settings on your computer, make sure you have not selected print in greyscale in the print options.
The manuals are available here:
( http://www.c5400.co.uk/index.asp?printername=C5400&menumode=0&content=c5400downloads )
http://www.c5400.co.uk/library/documents/c5400/C54xuEN1.pdf
http://www.c5400.co.uk/library/documents/c5400/PCSiGB1.pdf
I hope that helps
Jan 25, 2011 | OKI C5400 Laser Printer
Can i make the oki c5400 duplex
REQUIRES THE INSTALLATION OF A C5400 DUPLEX UNIT WHICH JUST SLIDES IN FROM THE REAR OF THE UNIT
Oct 05, 2010 | OKI C5400 Laser Printer
Reset Counters
There is no known way to do this!
Nov 05, 2008 | OKI C5400 Laser Printer
PAPER JAM AT DIFUSER , CHANGED IT BUT STILL JAMS
Your fuser roller needs to be replaced.
Sep 04, 2008 | OKI C5400 Led Printer
OKI c5400
  11. Check the COLOUR MENU – DENSITY CONTROL and set this to AUTO
  12. Check the COLOUR MENU – AUTO DENSITY and set this to EXECUTE
  13. Check the COLOUR MENUCMY 100% DENSITY is set to ENABLE if you want a glossier black finish.
Feb 17, 2008 | OKI C5400 Laser Printer
Oki c5400
Drum life for C5400 is roughly 15000 pages
Feb 09, 2008 | OKI C7350hdn Led Printer
Faint print or colour missing V V URGENT
I'm not an expert on these but I'd guess either the high voltage unit or LED laser PSU are suffering from an intermittent problem. If you're lucky it's just a loose connector - but I'll bet you've already tried re-seating every connector you can find :)
Sep 24, 2007 | OKI C5400 Laser Printer
OKI C5400 Laser Printer Logo
128 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
