Question about GE Microwave Ovens
I recently bought a microwave/convection oven. Model #JES1290SK 02. I understood that cooking time would be lessened for most recipes when using the convection oven, but it takes longer every time. Also, today I set the temp at 425 degrees. After the preheat bell rang, my oven thermometer read 325 degrees. I kept it in all during the recommended 45 min. cooking period and it only read 375 degrees at the end. The meat was not completely cooked as it should have been. Please advise what's wrong. You may call me at (814)695-5013 or e-mail back. Thank you. Kathleen Brinkmiller
  • Anonymous Mar 14, 2014
    Food is taking three times the amount of time to cook
  • GE Master
  • 9,086 Answers
GE Customer Service is here, and they should be able to help you.
They may refer you to the Answer Center.
Posted on Aug 12, 2008
I need a cooking manual for a Sharp Convection Microwave model R820BW
If you go to the Sharp web site and download the manual, or part you want, there are a few recipes in there, and it looks like they have an offer for a convection cookbook inside the manual.
Mar 16, 2014 | Sharp R-7A85 Microwave Oven
JES1290SK No power when on. Display works, work light works until enter is pushed. No motor movement
Does the convection work? If so likely you need a magnetron If the control panel is having problems then it needs to be repaired or replaced. It could be just a stuck relay inside so a firm hit may release it
Nov 27, 2013 | GE JES1290SK 1.2 Cu. Ft. Countertop...
Question: Can the Tastiwave oven be used?
I don't own one but per the TastiWave Quick Start Guide (which can be downloaded as a PDF document), The wattage must not exceed 1300 Watts. In the Instruction manual and quick cook recipe guide (also a downloadable PDF document) it states that:
"The recipes in this booklet have been written for an 1100 Watt microwave oven. Please adjust your “cook times” accordingly. Microwave must have a revolving turntable and the interior
must measure at least 14” wide x 14” deep x 7 3/4” high".
I hope this answers your question ;-)
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need the glass turn table asap. and how much does it cost? for jes1290sk
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=WB49X10174&productGroupId=0022&supplierId=364&brandId=0432&documentId=G0606370&keySuffixId=NA&modelNumber=JES1290SK02&keyId=1508&pageId=00001&productTypeId=0123245&searchModelNumber=JES1290SK02&subCompDesc=Microwave&brandDesc=GE&modelDesc=MICROWAVE&blt=11
Unless you can find one someplace else cheaper.
Eric
Dec 11, 2009 | GE JES1290SK 1.2 Cu. Ft. Countertop...
I've just bought a microwave/grill/convection oven combi but the manal isnt very comprehensive. i'm not sure what i can use to cook in with the convection oven function. can i use metal in there? eg. can...
Yes.
In convection mode, you can use anything that's oven safe. Anything you would use in a regular baking oven in other words.
There's a very interesting and helpful article on convection cooking here, and you can find more tips here.
Nov 05, 2008 | Microwave Ovens
Cooking in an old convectional microwave
Regardless of the model, the basic procedure should be the same in most Sharp convection models.
You can download several recent models here:
http://www.sharpusa.com/products/TypeManuals/0,1083,5,00.html
Nov 22, 2007 | Sharp R-1850A Convection/Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
136 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
