Question about Sony Audio Players & Recorders
We have a sony stereo model number hcd-dx80 and when we turn it on it wont work and all it says is push power protect? what does that mean and how can we fix it
  • kelz123 Aug 12, 2008
    Really!? Stink as!!!! Thnx 4 answerin my question :)
    Really! Stink as! Thnx 4 answering my question anyway =]
    Genius:
  • Sony Master
  • 1,550 Answers
Always be that legend for the audio amplifier IC damaged you need to replace him
Posted on Aug 12, 2008
Protect push power sony HCD-VX55
I believe I already answered this.
Feb 04, 2014 | Audio Players & Recorders
My sony mini hi-fi deck continue to tell me to i quote 'PUSH POWER;PROTECT' what do i do?plss help.
You PUSH the POWER control (OFF) because it is self protecting.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or
marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is
running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Sep 03, 2011 | Sony Electronics - Others
Sony home theater model no hcd-dz570 push power protect error on display what,s solution?
Check the speaker connection. One of them has a shortcircuit. Try to disconect all of them and power on the device. See what is happen. If starts corectly check the speaker cable. Conect one by one and power up the receiver after each connection. When you get the error again check the last conected cable. These receivers have a protection system against shortcircuits. That is puting your device in that error.
Jan 27, 2011 | Sony Audio Players & Recorders
IT DISPLAYS PROTECTOR PUSH POWER
its in standby, try it again, if it does it repeatedly theres a problem in the switching power supply not letting it power-up to save components
Oct 18, 2009 | Sony DAV-DX375 System
Sony stereo model HCD G5500 will turn on but no sound comes from speakers. I tested speakers on other unit and they work. I have the back off. Nothing appears to be melted or disconnected. What else can I...
Check fuse in plug check onboard fuses if all good look for black or blue or ornge little rectangular boxes(relays) should click if not then protection problem and needs to be serviced
Dec 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
HCD-XG500 it says push power protect
Power protect tends to mean the main power amp chip has "blown" and needs to be replaced. It only costs about 20 dollars (10GBP). If you are handy with a soldering iron it is easy to do (after you get the thing to bits !) It is the big black thing on the big heatsink inside. The Sony part number is STK442 - 130. Seems a waste to throw the whole thing away for the sake of 10 pounds !. Hope this helps. Nik Howell (nh@totalise.co.uk)
Apr 27, 2007 | Sony LBT-XG500 Shelf System
Sony lbt-x5g500
Oct 13, 2006 | Sony LBT-XG500 Shelf System
366 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
