Question about Cisco Catalyst 3560-24PS Switch
Access any command line
I have one switch and I can not move on to the privilege mode.
when I power on i have only this : "Switch :"
  • 30 Answers
That is the expected behavior of the switch.  If you want to go into privilege mode, you need to type "enable" at that prompt and enter the correct password.
Posted on Nov 06, 2008
How to switch on poe function at switch port
Hi
Instructions
telnet to the IP address of the Cisco switch
Enter the telnet access password for the Cisco swict when requested, and then the "Enter" key.
Type "enable" at the command prompt, and then the "Enter" key.
Enter the Privileged Exec password when requested at the command prompt, and then the "Enter" key. Then enter "configuration terminal" at the command prompt, and then the "Enter" key.
Type "interface fastethernet0/1," replacing the "fastethernet0/1" with the name of an interface in which you wish to enable PoE, and then the "Enter" key. Then, while in interface configuration mode, type "power inline auto" and then the "Enter" key. Repeat this step for each interface in which PoE is required.
Type "end" at the command prompt and then the "Enter" key, copy running-config
Below is some commands to run, I don't have any power on the interface but this will show you if this is working...
SW1#sh power inline fastEthernet 0/1
Available:360(w) Used:0(w) Remaining:360(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto off 0.0 n/a n/a 15.4
Run this command to see the interface is up.....
SW1# sh interface fastEthernet 0/1 ' in protocol
FastEthernet0/1 is up, line protocol is up (connected)
SW1#sh cdp interface fastEthernet 0/1
Encapsulation ARPA
Sending CDP packets every 60 seconds
Holdtime is 180 seconds
Thanks
Jul 31, 2014 | Cisco Catalyst Computers & Internet
Cannot access web interface
I'm going to assume you can get in the command line interface. Go into the command mode (type "config t" with out the quotes ) then type "ip http server" press enter, type exit to get out of command mode and then "write memory" to save your configuration. Remember, vlan 1 on the switch MUST have a IP address for you to be able to access the web interface.
Jan 03, 2014 | HP ProCurve 4208vl-96 (J8775A) 96-Port...
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Access denied
yes, you should be able to connect to the console port using a roll-over cable RJ45-DB9, connect using hyper terminal or similar using the com port settings 9600,8,N,1
You can then configure the switch from the CLI...
Have you set the 'Login' command on the VTY lines in the switch setup and an IP address on the management VLAN to connect to.
You also HAVE to have a password enabled on the vty lines in order to connect via telnet.
hope this helps.
May 09, 2012 | Cisco Catalyst 2960-24PC-S Ethernet Switch...
How Can I reset the SMC 8612XL3 switch to default factory mode?
hi there Ramesh -- please rate me
i believe i have what you asked for .. read on
i found the following information
a 2 page overview for this item
http://www.smc.com/files/AR/ds_8612XL3.pdf
home page for this item
http://www.smc.com/index.cfm?event=viewProduct&cid=8&scid=44&localeCode=EN%5FUSA&pid=1179
**MOTHERLOAD**
manual http://www.smc.com/files/AQ/MN_8612XL3_MAN.pdf
command.
Default Setting
None
Command Mode
Privileged Exec
Command Usage
This command resets the entire system.
Example
This example shows how to reset the switch:
Console#reload
System will be restarted, continue ? y
i hope this helps you
Nov 05, 2010 | SMC 8612XL3 101001000Mbps TigerSwitch 1000...
How do you perform a "factory reset" on a cisco c2912-lre-xl ?
From a console login, should look something like this:
Switch>
Go to privileged EXEC mode with the command "Enable"
Switch#
Enter the command "erase startup-config"
It will prompt you to confirm
When you confirm, it will bring you back to this prompt
Switch#
Now, enter the command "reload"
It will prompt you to confirm. And after a reload, you will be brought back to a screen that looks like this:
Press ENTER to begin
NOTE: if you are telnetting to the switch it WILL boot you out as you cannot keep an established telnet session without VTY line passwords and those are cleared by this process.
ALSO NOTE: This will NOT erase your VLAN data, VLANs are stored in a special file in Flash on a Cisco switch and SHOULD NOT be erased without professional help as there is a risk of destroying the IOS load on the switch.
Oct 07, 2009 | Cisco Catalyst 2912 LRE XL...
How to configure the router cisco with all parameters
3. Configuring your Cisco Router If you have just turned on the router, it will be completely unconfigured. If it is already configured, you may want to view its current configuration. Even if it has not been previously configured, you should familiarize yourself with the show commands before beginning to configure the router. Enter privileged mode by issuing the command enable, then issue several show commands to see what they display. Remember, the command show ? will display all the showcommands aavailable in the current mode. Definately try out the following commands:
Router#show interfaces
Router#show ip protocols
Router#show ip route
Router#show ip arp When you enter privileged mode by using the command enable, you are in the top-level mode of privileged mode, also known in this document as "parent mode." It is in this top-level or parent mode that you can display most of the information about the router. As you now know, you do this with the show commands. Here you can learn the configuration of interfaces and whether they are up or down. You can display what IP protocols are in use, such as dynamic routing protocols. You can view the route and ARP tables, and these are just a few of the more important options.
As you configure the router, you will enter various sub-modes to set options, then return to the parent mode to display the results of your commands. You also return to the parent mode to enter other sub-modes. To return to the parent mode, you hit ctrl-z. This puts any commands you have just issued into affect, and returns you to parent mode.
Mar 31, 2009 | 3Com Computers & Internet
Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# bypass passwords
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Serial Number: LBADTNXXXXXXXXX
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/NV5305A-12-01-07b-E.biz'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
bootstrap#boot
Mar 20, 2009 | Adtran NetVanta 1224R 24-Port Ethernet...
Cisco Catalyst 3560-24PS Switch Logo
243 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
