Question about Minolta Photography
Shutter stopped working
Minolta x-700 shutter stopped working ,,,new batteries meter works.Maybe one of these buttons?
dan
  • 667 Answers
If the metering lights go out when you press the shutter release fully down, then the camera needs the shutter capacitors replaced. If they stay on, it could be the release magnets on the shutter unit itself, or worse.
Posted on Aug 12, 2008
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
No shutter/film advance
Try to used a new film..
Let me know again..
Thanks
Apr 22, 2008 | Minolta Maxxum 700si 35mm SLR Camera
Whenever I touch the operating button to meter, the "under-range LED" will not stop blinking. No shutter speeds illuminate, not even the one I have the shutter set to. The only LED's that...
Be sure your mode dial is not in the auto position. If it is, the camera will only function with the lense also locked to the auto position, which will either be the lowest aperture (highest number) or sometimes an "A" setting separate from the normal aperture settings. That's generally what this type of indication means on program/manual models - that you're trying to use manual settings, when the camera is set up for auto program exposure.
Sep 08, 2011 | Minolta X-700 35mm SLR Camera
My shutter stopped working on my minolta X 700 how can I fix it myself.
It sounds like the same problem I had your capacitors need to be replaced. They store the energy needed to fire the shutter when you depress the button. Most camera shops are aware of this problem and the can obtain the parts. The replacement requires camera tear down and soldering in the parts. If you don't feel comfortable doing this then take it to the repair shop.
Jun 14, 2010 | Minolta X-700 35mm SLR Camera
Film wont advance
Metering lights are the LEDs that light up in the viewfinder. Camera on, look in the viewfinder to the right side you will see some lights. As long as these lights come on, P, M, A, *, ^ ,- You have put the batteries in correctly, and they have juice. Otherwise, you got the wrong batteries or put them in backwards.
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Sep 29, 2009 | Minolta X-700 35mm SLR Camera
Film Advance won't work on Minolta X-700
changing the batteries have no effect on film transport, just a coincidence. take the bottom cover off and check the white plastic gear on the film take up side of the camera. if it is broken your X700 may not be repairable as no new parts are available.
push the re-wind button in and try to charge the shutter again. remove film first. if it still just goes part way then a gear is stripped. try to find a camera repair shop that may have good used parts available.
Jul 18, 2009 | Minolta Photography
Light meter stopped working and shutter stopped firing
about the only thing you can do other than take or send your camera to a repair shop is to remove the batteries and clean the cap and contacts with a pencil eraser be careful not to damage the contact. also move the on/off switch and select knob back and forth a few times to clean the contacts. i would get a repair estimate first as there are no new parts available for this camera.
Jun 02, 2009 | Photography
Minolta x-300
The X-300 is very similar to the X-700 minus a few features like program 'P' mode. The VF displays are very similar for metering and exposure. You can read the users guide for the X700 here on
Mar 03, 2008 | Cameras
Light meter failure and shutter button sticking
Set your camera to B and release the shutter ( camera will work in this mode without batteries ) if you can wind ok and release shutter fine then all you need is new batteries. If however your camera is not working when set to B then it is either the shutter or the transport mechanism that need looking at. From experience ( have repaired 100s of Me-supers ) it is likely that your shutter needs attention : rubber components ( and foam rubber ) inside the shutter ( and the mirror box locking mechanism especially ) have perished and need replacing.
Sep 21, 2007 | Pentax ME Super 35mm SLR Camera
Photography Logo
554 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
