Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60" can not switch from ant a to ant b
The tv is hooked up to cable and in order to play the cable chanels the tv needs to be on ant A the cable chanels are showing but no sound can you help?
Where can I find a bulb for this tv for a good price
Posted on Aug 12, 2008
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Original-Style Super NES RF to TV Hookup
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Nov 25, 2011 | Nintendo Super NES Console
Hi, my Phillips was hooked up and working fine directly to the DISH receiver using the HDMI 1. I moved and had to put the DISH receiver in another room and ran a coax cable to where the TV is now using...
Hey murphypat321,
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at thomas.faust@dishnetwork.com if the problem persists.
Tommy Faust
DISH Network
Mar 09, 2011 | Philips 42PFL5332D 42 in. LCD Television
We move the tv from living room to bed room and we have to change the chanel from 3 to 60 to get the tv to work on dish network, we try to change from 3 to 60 we try evereything whit no result, we call...
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
Sep 04, 2010 | Televison & Video
Get nothing but static when i turn it on
make sure you go from the cable box were it says out to the in on the vcr from the vcr you want to come out to the tvnow you can program the the vcr to pick up the cable chanell from the boxthe vcr has to be on chaell 3-4 in the front were it shows what chanell your on then the tv and the vcr are to be on the wright cahells the tv has to line up with the chaell your useing for the vcr3-4 to make this less complicated put a tape in the vcr hit play if its playing you are on the right chanel you do not have to have the vcr to watch cable it will go threw even if vcr is off just have to be right chanel
May 18, 2010 | Sylvania 6260VF VCR
Just got a n64 off ebay power cable and an antenna cable came with it. no idea how to tune the tv so i can play it!!!!!! i have tried manually and automatically searching through all the components and...
It has been a long time since I have used one but I believe you can hook it directly to the rca jacks in the back of the tv... then I believe you need to be tuned into the AUX chanel on your tv set ... some tv's if you hit 00 this puts you to it ..others start from chanel two and go down ... hope it helps .. have fun playing the 64
Oct 16, 2009 | Nintendo 64 Console
Cannot get cable chanels on the tv
when you hooked it up to the cable box the tv has tobe in channel 3 or 4. In order to be able to select channels you have to select them in the cable box (also with the cable remote control)
Apr 14, 2009 | Coby Televison & Video
Don't have manuel and don't know how to Set up Hitachi VCR
Such a simple job. First check if the cables are connecred properly
1. Audio OUT from VCR to AUDIO IN of TV.
2. Video OUT from VCR to VIDEO IN of TV
Then switch the TV ON. Select 'Video' on the TV/Video
selection button on the TV's remote control.
Your TV screen will show a display like 'Video' or 'AV'
Play a cassette and you should be able to see the picture...
Happy Viewing.
Apr 01, 2009 | Televison & Video
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
Need to install a PS2 to a cable box.
unhook the cable box from the tv and hook that cable into the ant in on the modulator and run the output of the modulator to the tv.set the modulator and tv on channel 3.you may have to turn off the cable box to play ps2.please give me a rating if this was helpful,if you need more help just ask
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
