Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Fuse where is the fuse, behind wood panel in back, tv is 2 years old, would it be the fuse if it does the same thing after unplugging it and then plugging it back in again?
You haven't said what the problem was or is?
Posted on Aug 17, 2008
Dynex tv 2 years old shuts off while watching tv
Ensure that all connections are secured. Try power-cycling the TV by powering it off, unplugging it & leave it unplugged for a minute, and then plugging it back in and turning it back on. If you still experience issues, I would recommend bringing it into your local store for repair assistance. Keep in mind, if it requires repair, it may not be cost effective, and therefore, you may want to consider purchasing a replacement TV.
Nov 06, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
I have a 1 1/2 year old Panasonic TC-P42U1 plasma tv. While watching a show, it suddenly shut off and won't come back on. What do you think caused this and how can i fix it? Thanks.
Try unplugging it completely for 30 seconds to 1 minute. Plug it back in. If it still won't come on, it's likely taken a power surge and popped a fuse or power supply, which means a trip to the service center.
Jun 18, 2011 | Panasonic TC-P42U1 42 in. Plasma HDTV
My tv is 3 years old. I was watching it yesterday.Something poped and it went black. what is wropng?
A capacitor shorted (popped) in the power supply then the fuse blew (went black) unplug TV, remove back cover, look for power supply; follow cord to it; find small silver can with top bubbled (bad)
unsolder/replace; replace fuse. plug in turn on.
Mar 20, 2010 | Protron PLTV-32 Television
Pink and green lines are starting to appear that are moving up the screen TV is buzzing after being on for awhile. TV is not even a year old.
Try unplugging everything other than the TV and the cable (or whatever service you have) and while your tv is on, plug everything back in separately. I did this and found that while my ps3 was plugged in, I caught interference on my cable TV. Also, make sure that any cords behind the TV aren't all jumbled. Sometimes having a bunch of twisted up wires can cause interference.
Jan 25, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
My Whirlpool MH3184XPY is 2 1/2 years old. On
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails, it may be one of three fuses or three oven cavity thermostats in the unit.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from
the tag on the oven
here.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Jul 09, 2009 | Whirlpool MH3184XP Microwave Oven
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
DRYER TUMBLES BUT WILL NOT HEAT
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Jan 18, 2009 | GE DBXR463GD Gas Dryer
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
