Question about NEC Computers & Internet
When I start up my laptop it says internal slave not detected,boot failure
Well i suggest to reboot your laptop it deletes everything but it does the job....
when your starting the computer Tap f10 and the rebooting should start and your laptop will be up and running
Posted on Aug 12, 2008
How can I a boot disk system failure on my Asus without a system disc?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 30, 2012 | Computers & Internet
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
At first my computer cant detect my Maxtor HDD. but when i connect the sata port as a slave , it can detect the HDD. but after that it is showing " Disk but failure...." or " Disk read...
Restart the system and then press delete key when the computer start up then set the first boot to CD/DVD ROM then press F10 (save) and follow the instruction "press any key to boot from CD/DVD ROM after that First try to repair and if it's not satisfy. Please to format your Hard Disk
Hope it'll be helpful to you
All the Best!
Jun 30, 2011 | Gigabyte GA-945GM-S2 (0818313003065)...
I leaned my weight on the left side of my Inspiron 1525 by accident and this caused my computer to emit one long beep followed by a short beep continually. My laptop got the Blue Screen of Death with the...
The left hand side of the laptop houses the hard drive, the PXE-E1 media test failure is the laptop looking for another (network) boot device.
In short, you have probably damaged the hard drivem, which is why it is looking for another boot device
Remove the hard drive, check that the SATA connector pins are not damaged, if they are ok, then most likely there is no damage to the SATA connectors on the motherboard.
Test the hard drive on another computer ( as a slave) and see if it is recognised and can be read.
Listen for any knocking or clicking sounds, thay will tell you that the drive is damaged and needs replacing
Jan 30, 2011 | Dell Inspiron 1525 Notebook
I have a Maxidata msi 865GM3-LS (ms - 7037 Ver:1) Motherboard , have two hard drive as master and slave. Suddenly when opened the pc, I got a message disk boot failure and unable to ...
Not shown in BIOS!!!
How old is that hard disk?
Have you been receiving messages showing "SMART error" or something like that?
If yes, hard disk can be damaged.
Aug 11, 2010 | MSI 865GM3-LS (MS7043020) Motherboard
PXE-E61 media failure when i start up my computer
The PXE-E61 failure is a failure to boot to the network card, this generally indicates a problem with the hard disk drive.
  1. Boot to the BIOS and reset the defaults
  2. Reseat the hard drive
  3. Boot to Windows CD and run CHKDSK /R on HDD
If the system will not boot to the HDD, but it is seen in BIOS, then the HDD may have an OS issue, if not detected in BIOS HDD likely has failed.
Mar 02, 2010 | Acer Aspire 5315 Notebook
Laptop was unplugged while still running ans now
This happens when the battery dies and there is insufficient detectable power to run the boot system. You must change out the battery with a fresh one, or plug in a good external power supply to get things started.
You may also need to let the internal battery charge a short time before the boot system sees enough available voltage to start all systems.
Dec 19, 2009 | Computers & Internet
Hi i have problem in booting window 98 cd in my lenovo laptop. i want this because i want this for formating my leaptop with DISKMANAGER SOFTWARE but it not running the bootable disk.
in the bios you must enable auto detect for primary master, primary slave, secondary master and secondary slave if it is set to none your computer wont boot the cd.
i dunno what bios options they give you on your lenovo laptop.
is this a legitmate retail windows 98 SE disk?
if its a bootleg copy it might not be bootable.
don't forget to backup your data before you format
Apr 23, 2009 | IBM Computers & Internet
I have 2 GX520's that are buzzing when trying to boot
If your computer beeps during start-up:
  1. Write down the beep code
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM read/write failure
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer failure
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
1-3
Video Memory test failure
1-3-1 through 2-4-4
Memory not being properly identified or used
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller test failure
3-3-1
NVRAM power loss
3-3-2
Invalid NVRAM configuration
3-3-4
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No timer tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-1
Memory failure above address 0FFFFh
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-2
Failure to decompress code to shadowed memory
4-4-3
Math-coprocessor test failure
4-4-4
Cache test failure
Apr 11, 2009 | Dell OptiPlex GX520 PC Desktop
Disk boot failure when I installed a new SATA DVD writer
Start the system & enter you're bios & use you're manual to help guide you on this. Go to the Boot section of the bios. You can set the boot order. Normal boot order is like this:
1st boot device, floppy disk (if one is connected).
2nd boot device, cdrom drive
3rd boot device, hard drive
(Drive the has windows installed on it).
Save & exit the bios. The system will restart & windows should load. If it does not, than you picked the wrong hard drive.
Mike
Jun 17, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Computers & Internet Logo
37 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
