The
Caliper Adjustment Lever is what adjusts the caliper -
ensuring the brakes pads are in proper placement to the
rotor for effective braking. The lever must be cycled
in order to keep the calipers adjusted properly. The only
way the lever is cycled, is by the usage of the e-brake. Initial testing: After you have removed the ebrake cable - kneel
in front of the rotor and give it a gentle shake (as if
you were removing it). Do you notice any PLAY between
the pads & rotor?? Make note of this.
Remove
the cable from the Caliper Lever. Be careful when handling
and removing the spring.
The
For
the TSM kit caliper adjustment instructions - visit here: Troubleshooting.htm#2 and
click on "Adjust Caliper Parking Brake".
Good luck.
Testimonial: "Good attention to detail. Might be of soem help."
