I have a DLP 1080 Mitsubishi 65" big screen. Power went out about 1 week ago and green timer light keeps blinking. Replaced the major caps, 7 total, and it begin to work again. However, it stopped working again today. Tried reset, useless of course. Any suggestions?
  • 2 more comments
  • kent1388 Aug 12, 2008
    How can I determine which component is faulty without hiring an expensive repair technician?
    There are several fuses to this TV I understand, How will I know which one?
    Yes I had it plugged into a powerstrip and moved it directly to an outlet so see if it would work. It did not. Is there any test for the power cord I can run to determine if this is the cause?
  • kent1388 Aug 13, 2008
    Anyone on how I can test the power cord??????
  • 3,037 Answers
If you have a meter, you can test basically anything in the circuitry. You can get one from any electronics store. This will enable you to test the power supply
Posted on Aug 13, 2008
    Genius:
  • 1,665 Answers
Check also for any loose or bad wire harness board connections.
http://direct.where2getit.com/cwc/apps/w2gi.php?template=search&client=mitsuservicer#?mid=174138
Posted on Aug 12, 2008
    Genius:
  • 1,226 Answers
Hello:
Since you have replace some major caps, Try to find out the regulator and the resistor in the circuit board, which is the main causes of the errors, you should find that since also may cause fuse blown out near the power source. its easy to recognize busted fuse or you may use tester.
melnavz
  • 876 Answers
Sounds like a power source problem to me. Perhaps your power cord is damaged. Did you have it plugged into surge protector? the company warns against attempting to replace the power cord your self.
If you have questions regarding your television, call
Consumer Relations
at (800) 332-2119, or email us at
MDEAservice@bigscreen.mea.com
How frustrating for you! Good Luck!
    Master:
  • 848 Answers
Just check whether your fuse is blown ... also mitsubishi gives this error when it does not detect a video signal.....Check your wiring.
  • gopinath pasupathy Aug 12, 2008
    just check the near the inverter whether any fuse is blown ......
    Scholar:
  • 191 Answers
You need to determine the exact components which one has been blown this time and then you need to replace them.
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Mitsubishi green blinking light of death
Hi Jim,
Green blinking light of death on Mitsubishi DLP TV means that the DM failed to booted up. I would advice you to replaced the 7 1000uf electrolytic capacitor on the DM board. Most of the time it fixed the symptoms. Please inquire at tvrepairworld.com if they have an available DM repair kit for V36 chassis (WD-57733 chassis).
Jdvillanueva
Jan 10, 2012 | Mitsubishi WD-57733 57" HDTV
"i have a mitsubishi HDTV
The green blinking light is telling you the error code. count the number of blinks and make note of any sequence. Then google your make and model with blink codes added to the end. This will lead you to sights that will tell you what the error or blink code means.
Aug 20, 2011 | Mitsubishi Televison & Video
I have a mitsubishi dlp WD-65733 and it went out on me a week ago. when I power it up i get only the green light above the timer. when i hit the reset button in the front i hear a click in the back and the...
It seems problem in power supply board that got few electrolytic capacitors leaky and causing problem. It does not look like lamp issue.
Let me know are you handy with electronics stuff repair and can replace parts in circuit board?
Thanks.
Apr 06, 2011 | Televison & Video
I lost power yesterday and since it came back on, my TV will not turn back on. the green timer light keeps blinking. i have unplugged and reset but no dice. it is a mitsubishi medallion 1080 that is...
We were in chat session and lost chat contact,
Though all necessary info have already been provided yet let me know if you have further question.
Thanks.
Dec 13, 2009 | Televison & Video
MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Nov 01, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
The 52525 is definitely going to either:
1. have the caps on the FMT/DM board replaced (not something I'd recommend you do yourself)
2. have the electrical chassis rebuilt (as sometimes, you can replace the caps and still have the problem).
wait time: 4-8 weeks
cost to rebuild: $400-$500
cost for labor: $200-$400
Oct 13, 2008 | Mitsubishi WD-52627 52" Television
Mitsubishi Projection TV model WS-65513
Good Day;
The continues blinking 99.9 % of the time is four caps on your DM board. The caps are C9B01,C9B02,C9B10 and C9B11 they use 1000UHF the upgrade caps are 680 UHF- 35V. The board is on the very left hand side (from back).
I have performed this repair at least 50 times and it takes me still about 1.5 hours. If you are not handy and do not have a solder station, I would recommend that you call a factory authorized service dealer to perform this repair. With service call and ect. it will cost you around $550.00 and the repair can be done in the home, of course prices varies across the country.
Good Luck, Day, Big Irish.
Apr 11, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 65 inch Diamond rear projection
Sounds like your control unit has going down. its the big silver box in the rear to the left of the set.
Oct 28, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
