Try to unplug it from the main socket and from the wii, leave it for about 10 minutes then put it back. If this doesn't change anything then it's most likely the charger's fault. The problem with Wii's charger is that there is no light for you to check whether there's enough power coming through the cable. If you can borrow a charger from one of your friends it'll be good as this will help you confirm whether your charger is really faulty. If not, buy yourself a charger. You can find this from your local store or off ebay.
hope this helps.
Swap the power adapter with someone else's Wii, just to test it.
Also, are there any USB devices connected? If so, disconnect those and try it again.
It sounds like the power cord could be going bad. Check the connection to the wall and the wii first and if those seem like solid connections, I would try to get another power cord. I've bought a second one for myself and they are fairly cheap.
http://cgi.ebay.com/NEW-AC-Wall-Power-Adapter-Supply-Cord-Nintendo-Wii-/190511050160?pt=Video_Games_Accessories&hash=item2c5b57edb0
