Cameras Logo
Posted on May 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sir, My computer is showing me an error when i try to open the camera. Shown error by the computer is "Creation of the video preview failed. Please check the device connection and make sure that the device is not being used by another application or user." Sir i request u to please solve my problem.. Your sincerely Sumit kumar singh
Anonymous
Level 2:
New Friend:
  • Expert 30 Answers
  • Posted on May 05, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
30
Questions
0
Helped
10422
Points
111
That means that another program or device is using the camera or video. try to unplug the camera then plug it back in. also make sure you have other windows close, like a video viewer, other programs.
3helpful
"parser error: value creation failed
To get rid of this error you can switch back to a Microsoft Theme or go to /WINDOWS/Resources/Themes/ and rename the shell folder to the name of the visual style shown in the appearance tab.
If that doesn't help and it should, more info here: http://www.jsifaq.com/subo/tip7400/rh7458.htm
This is problem with C:\WINDOWS\System32\Shellstyle.dll
Copy the shellstyle.dll file from a working machine of same service pack level to your System32 folder..
My lenovo easy capture camera is not work when i start it the error shown creation of the video preview failed please check the device connection and make sure that the device is not being another...
my lenovo esaycapture your problem is capture image in video the image is down, example yesterday my nephews use program image down, what is the problem and resolve it. Thanks for your help.
When i open ilook 110 from my computer a message appears that creation of the video preview failed. please check the device connection and make sure that the device is not being used by another application...
Disconnect the camera from the computer, then uninstall the driver software through the control panel by deleting the device. Then, reinstall the camera by first rebooting and verifying that the camera driver software has been removed. Then, reconnect the camera, and reinstall fresh software from the manufacturer or off of the Internet. Then, the problem should be solved.
1helpful
I open the cam a4tech 635k it say creation of the video failed.
check if their is any program that are using your camera. closed any open program that related to your camera.
or try uninstall the software of your camera be sure you have to restart the pc after uninstalling, and install it again your camera sofware and driver.
I have acer 5738 laptop my inbuilt webcam not working. driver installed still not working showing message creation of video preview failed please check the device connection and make sure that the device...
try to re stat your computer after opening it, press CTRL+ALT+DEL then on the task manager closeal the application that might be using the camera.
Check it first
I can't capture photos
to use the power dvd s/w first to see the full of cd and caputure the part to right click the bar to show on that use themthey didn't slove msg me iwill help you
I cannot preview my video on my quickcam orbit mp
check the dm for enumeration, if the cam is present under imaging devices. uninstall all of the logitech software and plug camera in without the software. cam should come up generic USB device the try to preview in skype. if workinf reinstall sotware from the logitech websight.
Video preview failure
i already install the driver of my a4 625 but when i open it there is a message that there is no capture hardware.pls help me it my problem
Dec 12, 2008 • A4tech PK5
Card shows read error in Preview Mode
Let's try a couple of easy things first. Remove the card and clean the contacts with a soft cloth. Next, try connecting the camera to computer, and "right-click" on the camera icon. Go to "properties", "tools" and perform an error check on the card. Open the card and see if there are any files or folders that shouldn't be there. Delete them if there are any. If you absolutely need to recover the images, you may need to try image recovery software. Some are free downloads and vary in effectiveness. If the images are not super valuable, you should be able to format the card in the camera, which will wipe out all data, both good and bad. The card should then be useable, and void of any images. Good luck.
Error in preview cam & video
f26c97c.jpgIt is belt problem which leads your camera not to show preview. It is repairable by skilled technician. If you are not skilled then requested to consult servicemen and he will do the job for you.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
