Question about JVC AV-24F702 24" TV
Help... i put the sleep timer on one night and suddenly the remote stopped working, and there's a red "N" in the bottom right corner of my screen that wont go away...and before i get any replies about putting new batteries in the controller, i've already tried new batteries, and i cant even program a universal remote for the tv...what's with the "N" and how do i get rid of it...?! i've been putting up with it for over 2 years now!
If you have menu controls directly on your TV. You might try resetting all the settings.
Posted on Sep 05, 2008
Sleep button
use the buttons on the front ... press them all until your menu comes up on the screen.....also you could try finding the manual .... buy a universal remote ..... buy a timer for the plug ... turn off the tv . stop watching tv before bedtime .... ask some1 to pop in and check if you have fallen asleep with the tv on , mums are usually always willing to do this for you , but i'd advise caution if your watching adult rated comment they usually do not condone this content ...let us now which option you go for and how it works out for you ... good luck friend
Mar 29, 2014 | Olevia Televison & Video
Television "locked"
Hello can you please post the brand and model of the television so we can find unlocking instructions.
Jun 18, 2008 | Televison & Video
Samsung flatscreen wont turn on but red light is on showing power son used sleep timer last night
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
then PRESS RIGHT NAVAGATION KEY the tv will reset
the tv will need retuneing after
hope this helps
Dec 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
My remote does not have the sleep timer button.
Open cover on the bottom part of the remote SLEEP button is there.
Sep 09, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Need to get rid of closed caption
If you have original remote for t.v. , hit the button under the sleep timer button on remote, and eventually the closed cation words will be removed from the bottom right corner of t.v. Hope this helps , good luck .....
Jan 07, 2009 | Broksonic CTVG-5463GVC 19" TV
Zenith B27A11Z remote stop working
remove the batteries from remote ,then put im back and then try again
Jan 01, 2008 | Zenith B27A11Z 27" TV
Where is the sleep timer????
just checked a similar sets owners manual...the sleep timer on this model is located in the menu---setup,,this menu prompt has language,SLEEP,menu trans,menu timeout ,and default setting....if you don't see the SLEEP mode in setup--you probably don't have it!...hope that helps
Aug 20, 2007 | Initial DTV-322 32 in. TV/DVD Combo
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
JVC AV-24F702 24" TV Logo
90 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
