Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
HP PAVILION when i try starting my HP the screen will not boot up even with an external monitor i know it cant be the battery because even without the AC adapter it will power up it just wont show up on the monitor anyone got any suggestions
  • 1,142 Answers
Please go through this link
Posted on Aug 12, 2008
HP Pavilion dv4-2145dx stop working
while its off try holding down the function key and the microsoft key and the B button and press the power button and hold all of them down for 5 secs that will get u into the bios look around in there be careful set it for default settings maybe even test battery in bios thats just 1 thing the next step would require a couple small purchases to eliminate the easy things let me know if you want also take out you cd drive gently while laptop is off all the way off not hibernate let me knowl
Jan 14, 2013 | HP Pavilion dv4000 Notebook
Screen not lighting up on my hp pavilion
Try on an external monitor, if it works ok, you can rule out the graphics chip problem
If it does boot to an external monitor, the screen backlight / inverter has died and needs replacing
If it does not boot to an external monitor, the graphics (nvidia) chip has done the famous DV series trick of unsoldering itself and will need professionally reballed
Jan 04, 2011 | HP Pavilion dv6000z Notebook
Hp pavilion slimline s3100n doesn't display on the monitor. boots fine and fans spin and stuff, it just doesn't recognize its own VGA output. What do i do?
First,try hooking it up to an external monitor if you have access to one.Unfortunately,we need video to start checking for what may be wrong.
Try the monitor and post back to let me know what happens,and if it shows on the external display we can start looking at potential problems and fixes.
Aug 21, 2010 | HP Hewlett Packard Pavilion Slimline...
I have an HP Mini 110. I have turned off the
Try this: Remove Mini from A/C power; remove battery. Hold power button for 10 seconds; reinstall battery & A/C power. Try starting normally. Your netbook doesn't appear to have an external VGA port, or I would suggest trying to connect to an external monitor. Your monitor back-light may be burned out.
Mar 10, 2010 | HP Pavilion ze2000 Notebook
Black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Jan 09, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
HP notebook does not boot
Try plugging the external VGA adapter to an external monitor. If you see your desktop or post boot on the external then most likely the lcd screen is bad or you may get lucky and it just be the "backlight tude" Either way I would replace the lcd screen with a new one if the backlight is already shot. You can buy a new screen for around $99 and they are fairly easy to install. Again confirm you have picture to an external monitor b4 you buy a new screen.
Dec 29, 2009 | HP Pavilion dv6000z Notebook
Hello, I have a problem with hp pavilion dv
Try lowering your display settings when it is hooked up to the external monitor. Then try the laptop screen again.
Right click an open area of the desktop, select properties, click the display tab. In the lower left of the box there is a settings slider, try lowering the settings and see if it gets better.
Dec 13, 2009 | HP Pavilion dv6000z Notebook
HP (dv2000) laptop will not boot up at all
It appears to be a video card/mainboard problem very common with the symptoms you have described. Try to connect the laptop to an external monitor (see the associated buttons too). No video signal on the external monitor could indicate a damaged video card/mainboard. Not worth it to be repaired and the replacement is expansive. Check the price on a professional repair store. There are new laptops on the market more powerful than yours for about 500-600$. So you can make a choice. Less common, could be a memory problem.Try the laptop with a good previously checked memory (or if there are 2 bars in your laptop, try them one by one). If you do not get any video signal on the external monitor have the laptop, first diagnostic is most probable.
In both cases, if you get a video signal on the external monitor it means your screen is defective (also expensive to be replaced).
Oct 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Laptop won't boot up black screen
its *********** board. i found a solution for the smae problem on youtube worked like a charm,
Apr 24, 2009 | Computers & Internet
Lost screen
you need to find out if your screen is bad. does it sounds like it booting up and you hear the sound when windows boots up? you can also try connecting your laptop to an external monitor. if you see a display on your monitor, then you screen on the notebook will need to be replaced, if you dont see a display on the external monitor, then you have most likely a bad mainboard , you might have a bad ram module too. but most likely the main board
thank you
Apr 19, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
151 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
