Question about Navman F20 GPS Receiver
Navman problem My navman is in another strange language. I tried switching it off. I let the batery go dead and on again, to get the option at the start, to choose my language. It is not bringing up that option to select language or country. WHAT CAN I DO
How can i change my navman from German to English. Thank
  • Press the "Main Menu" button on the Navman to bring up a list of options. Tap "Preferences," choose "Localize" and "Language." Each option is selected by touching the screen. The different language options show up on the screen in list format. Touch the language you want to use and press the check mark icon. The Navman will now operate in the chosen language.
  • Jul 01, 2011 | Computers & Internet
    I pushed the German language instead of English, I cant proceed
    Enter the text you can see into the free translation service below:
    http://ets.freetranslation.com/
    It will give you an idea of what option you are looking at.
    HTH
    Peter
    Jan 16, 2009 | Navman F15
    Navman operational problem
    If you can get to your settings area it looks like a little gear. Go 6 options down and touch it and you should be able to change it there. The user manual is in the link below if you need more technical information.
    http://www.navman.com/in-car/3294/Australia/Navman-Australia/Our-Products/Current-Products/S150/
    Jan 03, 2009 | Navman GPS
    Navman S reset
    Please go to Preference option on your navman. From the main screen you can setup the following preferences.Now scroll to 3rd page of the prefrences.There you will see the following options:
    • Start Up – enable/disable the tutorial and language selection screen that appear when the system is switched on.
    • Saved Info – here you can delete recent locations, favourites, avoidances and reset to factory defaults.
    • Bluetooth – this option allows you to setup bluetooth pairing with a mobile phone.
    • Tutorial – run the tutorial that appears at startup.
    • Shop Demo--runs a demo so you can see the Navman S50 in action.
    Just select the SAVED INFO option and then you will see a RESET TO FACTORY DEFAULT OPTION.
    Jul 23, 2008 | GPS
    Navman
    Jul 23, 2008 | GPS
    Navman F10 Software Update
    Hi, I had the same issue. Found the Navman F10 software via the navman New Zealand website.
    link: http://www.navmansupport.co.nz/Software/F%20Series/F10/NDD001___347.htm
    once downloaded the F10 PC software, redownload your language voice to the F10 from the navdesk software you just installed on your pc.
    Note: if the voice is already on the f10 and it's not working, try removing it then redownloading the voice again.
    Once downloaded to the F10 select the required voice from the settings menu.
    cheers.
    c.ellis.
    Jun 06, 2008 | Audio Players & Recorders
    Sat nav
    GO TO PREFERENCES ,LOCALIZE , LANGUAGE, UK OR US ENGLISH . EXIT BACK TO LANGUAGE , TAP VOICE , MALE / FEMALE TAP TICK . ALSO INCREASE VOLUME ON SIDE OF NAVMAN + OR -
    May 02, 2008 | Navman F20 GPS Receiver
    Navman s 50 changing voice from male to female
    Navigate to Settings Preferences page 2/3, tap Language,
    choose your preffered voice settings.
    Find online manual here:
    http://www.activegps.co.uk/car-navigation/navman-s50/navman-s50.pdf
    (Voice settings at page 84 in the manual)
    Apr 12, 2008 | GPS
    Navman F20 GPS Receiver Logo
    71 people viewed this question
    Top Navman GPS Experts
    Martin Murray
    Are you a Navman GPS Expert? Answer questions, earn points and help others
