Question about HP 303178-001 Compaq TC1000 TC1100 Tablet PC Keyboard
Keyboard sometime doesn't response my hit
If I hit the key quickly (less than 1 sec delay) about 3 or 4 character, the next character doesn't typed again. The sound seem say just unplug hardware. It's seem the keyboard is unplugged. Anyone know about this problem?
I had the same problem but it was limited to specific keys anyway I learned that it was part of a common problem although it is an uncommon symptom because other problem usually occur before this all resulting from one cause and most people will have fixed it before it gets that bad. You need to download the Tablet PC Transmeta Crusoe Code Morphing Software Upgrade, after you install this upgrade you will most likely find other little problems that you've ignored will go away (like a ding sound and the mouse/keyboard freeze, when using the ball on the keyboard sometimes seems to have a mind of it's own)
The address below will take you directly to the page you need to start at when you get to it click the button that says download and follow the instructions. There are quite a few updates and upgrades for the tc1000 available on that site and you should take some time to look through and see if there are other problems you're having that there are solutions for.
Good luck, I hope this helps!
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=0&prodSeriesId=307008&swItem=PSG_I18120-101252&prodNameId=307010&swEnvOID=1059&swLang=8&taskId=135&mode=3
Posted on Sep 05, 2008
  • 981 Answers
What?  No, that's pretty whacked.  Does it happen in all OS, even if you boot to a LiveCD?  I think your OS has a wacky driver or IME loaded for it, but it could be an unplugged (or bad USB connection) thing all right.  Get in there and confirm your connections are solid, and check your IME (input method filter, e.g. for typing in Thai.)
Posted on Aug 13, 2008
SOURCE:
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Tip
    How to Configure your Linksys router with wireless security
    Launch your Internet Explorer, Netscape or your Mozilla.
    On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
    Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
    If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
    To reset the router to factory default
    1] Press and hold the reset button for 30 sec., after that
    2] Unplug the power keep holding down the reset button for another 30 sec.
    3] Then, plug back the power keep holding down the reset button for 30sec., after that
    4] Release the reset button.
    Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
    Cisco Interface (If your Setup page has a Cisco Logo)
    Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
    Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
    Under Setup > Click WEP Key Settings or Edit WEP Key Settings
    Using passphrase 64bit
    Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
    For manual key entry of 64bit encryption:
    Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
    (e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
    Using passphrase 128bit
    Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
    For manual key entry of 128bit encryption:
    Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
    (e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
    If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
    on Jan 06, 2010 | Computers & Internet
    My keyboard typing multiple letters
    Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard\'s repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
    Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
    If fails
    Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol to get it sparkling clean
    If you are still feeling industrious, next you can tackle cleaning your mouse Of course, if cleaning your keyboard seems a truly undesirable task, you can always buy one for around $20.
    Hope this helps.
    Dec 31, 2012 | HP Computers & Internet
    When you are typing it will type the symbols instead of the letters, you have to keep hitting the function button for the letters to work, sometimes it will work hitting it one time other times you have to...
    Hi
    Try system restore. Go to START>ACCESSORIES>SYSTEM TOOLS>SYSTEM RESTORE>CHOOSE PREVIOUS RESTORE DATES. Use other restore dates if needed.
    Or try this
    If your laptop keyboard types wrong characters, it is rather a software issue than an hardware one. This can happen if you accidentally press certain keys on your keyboard, which enable a certain kind of function.
    Try the following steps in case your laptop keyboard displays wrong characters:
    1.Go to the control panel option
    Click ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
    2.Select the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
    3.Ensure that all the check boxes are unchecked in this window and do the same for 'Switch to...(Keyboard Type)'
    4.Click ?
    'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
    This should solve your problem
    Jun 24, 2011 | Acer Aspire One AOD150-1920 Netbook
    My keyboard keys have a delay response. i have to hold the key down for about 1 second before the letter appears. why?
    Try going into Control Panel- Keyboard-- adjust character rate and repeat rate. Might fix ya right up..You might also want to replace the batteries....
    Apr 18, 2010 | Compaq Keyboard
    Frustrating problem with spacebar causing skip
    did you tried to clean the inside of the keyboard coz sometimes the dust is the cause why some characters not working properly.
    Sep 16, 2009 | Computers & Internet
    Rt7d40 dell keyboard is non responsive
    probably need to clean your keyboard
    check keyboard settings in control panel
    Nov 13, 2008 | Dell Wireless Keyboard Optical Mouse w0147
    Delayed keyboard response on Dell Inspiron E1705 Laptop
    Is the mouse response sluggish as well during these times?
    In most cases, it means the computer is busy with another process. The keys you press stay in the keyboard buffer until the CPU has time to process them.
    Check your CPU busy time when this happens. In Windows XP, press ctl-alt-del to start the task manager, the select the processes tab to see if one process is tying up the system (by % of CPU), or press the performance tab to see CPU usage. If it is pegged at close to 100%, something is tying up the system.
    May 12, 2008 | Compaq Presario 700 470024-192 Notebook
    Cannot get backslash (\) character to display
    To get a backslash, you need to print the upper ascii character 92 (decimal). On most machines you can get upper ascii characters by holding down the Alt key and typing the decimal value on the numeric keypad. On the little IBM machine I'm typing this on, there is no numeric keypad, but if I switch on numlock (by doing shift-scroll-lock) the j-k-l keys become 1-2-3 etc. Now id I hold down Alt and type 92 (i.e.keys 9-k), this is what I get: \ Howzzat?.
    Mar 16, 2008 | IBM ThinkPad 600X Notebook
    Keyboard problem
    Information about computer keyboards Now with new technology, stuck keys are no longer an issue; ... Given all the above problems
    Information about the AT and PS/2 port 1, Keyboard Clock. 2, Keyboard Data. 3, Not Connected or Keyboard Reset
    Device Manager information and help Users who have a keyboard with a windows key may also quickly get to the system .... CODE 2 (Second Error)
    This should get ya back in to typing again/Good Luck.. Please dont for get to Vote, Thank You.
    Dec 19, 2007 | Acer Aspire 3680 Laptop
    HP 303178-001 Compaq TC1000 TC1100 Tablet PC Keyboard Logo
    165 people viewed this question
    Top HP Computers & Internet Experts
    Ekse
    Thomas F. Schneider
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
