Question about Philips Magnavox 27MT5405 TV
Horizontal lines after power on, then shutdown
Model 27MT5005D shutsdown after power on. Replaced cap 2465 10uf 100v capacitor to fix horizontal lines, but still did not fix problem
TV is about 2 years old and still has horizontal lines going across it. What part would you try to replace next.
Looked up parts lists and all i can find is in Chinesse*
  • davexbox360 Aug 12, 2008
    Terryfic, i am sorry i wasted your time i just trashed it last night cause i fixed a better one i had setting around.
    Thanks for your time
  • Vista Electronics May 11, 2010
    Verify Model & Chassis # from back of set...
    Terry.
    Genius:
  • 1,694 Answers
No Worries...try me again sometime....T.
Posted on Aug 12, 2008
Philips md#32PT9100D/37 will not turn on only
Hi
Your tv set may have a short circuit both in the power supply and horizontal output stage. The first approach I suggest is to check the rectifier fast diode in the line supply (90/100V) for short. This model is prone to burn this component and may be associated with some problem in the horizontal output or even in the RGB output.
I would like to point out that this task require a technician as should be supported with a schematic of this model.
If this is helpful, I shall be glad.
Sully
Sep 22, 2013 | Philips Televison & Video
MY Panasonic CT38HL43 has a problem it will not turn on. I press the power button it goes on and then it kick off like it tripped a breaker. Then teh power light slashes abootu every 10 to 15 seconds. I...
hi there,
yah.. you must check the fuse on the powersupply area & also one on the non-powersupply area.. if you see some bad fuse and ic, then you must replaced it..
if my info/idea helps you, please kindly rate my solution.
Thank you
May 27, 2008 | Panasonic Televison & Video
White horizontal line is coming how to solve this
Since you changed the flyback did anything change? If not, you may want to take a close look at the horizontal peaking caps or the horizontal electroltic capacitor. I hope this helps.
If I can help any more, email me at wyoed1@aol.com
"Original Radio Man"
Ed
Feb 13, 2013 | Televison & Video
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba Problem
Look, replace all capacitors around horizontal transistor, if dont work, adjust eprom.
May 12, 2008 | Toshiba CF36H50 36" TV
WD-62525 horizontal lines in picture when using component inputs
code 12 means the set isnt experiencing any shutdown symptons. I would check for more capacitors in the same circuit where you found the other often they show no visible sign of deterioration. If you need a service manual to figure out which capacitors are in that same circuit you can get the manbual for your set for 10.99 at the following link. They will even email it to you if you go back to the site and let them know you want it emailed. heres the link hope it helps.
http://servicemanuals.vstore.ca/
Jan 05, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Horiz. lines across top of screen.
I agree with solution #2
I recently had my phillips 27" model 27PT6341/07 repaired after warranty expired due to white lines appearing at the top of the screen. The shop advised that it was a capacitor giving me the problem. So, after getting it back, I examined the repair job and the shop had replaced a capacitor at the back of the main board, next to the rear rca inputs. It is labeled 10uf 100v. I was told that it would fail again soon because it is a manufactures defect. For me it is at location 2465. Here are a couple of photos of the part.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
Good luck,
Ed
Nov 13, 2007 | Philips 27PT6441 27" TV
Power on problem
You might have a cap that shorts after it heats up causing your problem. The whinning sound you hear sounds like the power supply has a short on it. Usually when this happens though, it doesn't go away until some part such as the horizontal output transistor is replaced. RCA's are notorious for flybacks shorting and then shorting the horizontal output transistor. Your flyback may be shorting intermittently. Strange! Stargazer
Feb 26, 2007 | RCA F25254GY 25" TV
Philips Magnavox 27MT5405 TV Logo
166 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
