Question about Timex 27191 Wristwatch
Timex Indiglo WR 30M
I can't get the alarm disabled - How do you turn the alarm ON or OFF?
  • 3 more comments
  • elmertx Nov 01, 2008
    Cannot ddisable the alarm
  • zmaendel Nov 10, 2008
    I have the same problem. How to turn off the stupid alarm! lol
  • rfairchild Nov 14, 2008
    How do you turn off the hourly chime and the alarm?
  • Anonymous Nov 22, 2008
    I have the same problem.  My alarm goes off at 12:03 pm every day.  I have the same watch.
  • xanthus Feb 07, 2009
    can't turn off alarm
To turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
Posted on Dec 30, 2008
Try holding in the bottom right button (Lap/Reset) and then the top right button (Start/Stop) should toggle the alarm on and off. That worked with mine (WR30M with no further description available) just now so good luck!
Posted on Nov 28, 2008
It helped me ... thanks Flarkblam
Posted on Dec 31, 2008
3 Suggested Answers
SOURCE: How to change battery for Timex Indiglo WR 30M
I ended up putting the watch between two layers of a shop rag and tightened it in my garage vise. First try didn't work so the second try I turned the vise another /14 turn. Voilla! Stupid watch!!
Posted on Sep 23, 2008
cmcduncand
  • 714 Answers
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
Alarm off
- Keep on pressing mode button on watch till alarm mode appears.
- to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
- press adjust button to disable
- or press two buttons on right of watch to adjust the alarm
Mar 29, 2014 | Casio G-Shock World Time Analog Digital...
I accidentally hid
To make the alarm appear press the button at 8 O'cloc.
To turn off/on the alarm press the button at 2 O'clock.
Jan 05, 2010 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Can't disable the alarm, the alarm goes off at 11pm every night and i want to disable it so that it no longer chimes at that hour. what do i do?
Press lower left hand button until you reach alarms may say snz or sig use the bottom right hand button to cycle through the options, to turn an alarm on or off press the adjust button top left you will then see off or on in the lower circle on the watch face. Also there is a graphical display at the top of the screen Alm sig and snz when there is no black bar here all alarms are off.
Dec 21, 2009 | Casio G-Shock G701D-2AV Wrist Watch
I need instructions on setting the alarm for the Pulsar Chronograph 100M. I'm able to set everything else. Your response is greatly appreciated. THANKS!!
I answered this for different Fossil watch post, but I believe it will be the same for your watch.
I'll re-post the answer below.
To set the alarm on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#0), FIRST CLICK (#1) & SECOND CLICK (#2).
The small dials located at the bottom of the watch face (6 O'clock) are the alarm minute and hour dials.
First, pull the crown out to the second 'click' (position #2) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #2!)
Second, set the correct time. (plus one or two minutes... time to complete this.)
Third, with the crown still out to position #2, push button "B" (bottom) until the alarm minute and hour hands are set to the present time (same as the large dials).
Fourth, push the crown all the way in- to position #0.
The current time on the large dial should read the same as the small alarm 'time'. {This is the CURRENT TIME, not the alarm SOUND SET.}
To set the alarm SOUND time, pull the crown out to the first click (position #1).
Push button "B" until the dials of the alarm are at the time you want the alarm to sound... It can only be set within 12 hours! ... It does NOT know "am or pm".
When the desired time is set for the "alarm sound", push the crown all the way in (position #0).
The alarm dials will now indicate the time for your alarm to sound, NOT the current time. (this way, you know that the alarm is engaged.)
To reset the alarm- or disable it, pull the crown out to the first click (position #1) and hold button "B" down until the dials advance and stop at the current time... it will stop at the current time- then release button "B". --- Push the crown back in (position #0) and the alarm will now be disabled.
If the alarm dials are always moving and at the current time, you know that the alarm is disabled.
If the alarm dials are stationary and not moving with the time, you know that the alarm is engaged and set to the time shown.
I hope this helps.
Nov 05, 2009 | Pulsar Chronograph Watch
Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Aug 30, 2009 | Timex 1440 Nylon watch
How do you turn off the alarm
What you need to do is hit "Mode" until you're in alarm mode, then hit start until all you see is :00, then if you hit adjust it'll disable the hourly beep. To disable the alarms press the start button until the alarm you want to disable (Will appear on the screen above the mode button) then press but don't hold adjust, the AL1 -5 should disappear from above the mode button now.
Jun 02, 2009 | Casio F91W-1 Wrist Watch
How do I cancel the alarm?
Follow this link and find instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
Mar 11, 2009 | Watches
Remove alarm schedule
go to each alarm and press the upper button on the left side to disable the alarm
Feb 26, 2009 | Casio E-Databank EDB6101C Wrist Watch
Timex 27191 Wristwatch Logo
6,960 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Jim Dowell
Are you a Timex Watch Expert? Answer questions, earn points and help others
