Question about Honeywell Heating & Cooling
Replacing the thermostat, took the old one off without marking the wires. Hooked it up by color and we get the furnace when we put it on cool. wires are green, red, yellow & blue (ground wire)on the wall. The new thermostat wires are red, yellow & green. Can you tell me which wires go where correctly?
  • 182 Answers
The normal wiring for stats is white=w=heat,red=r=24volts,green=g=fan,blue=c=common,yellow=y=cooling.
see what ties into your furnace board and match the terminals.
Posted on Aug 12, 2008
Havc thermostats
I will assume you did not write down what color wire you took of each letter on old thermostat? Sometimes color of wire doesn't matter as some installers will use whatever color. If you noted where each wire was on old thermostat, just put same color wire to same letter on new one. Under normal situation. y is for compressor (cool) G, is for fan (on AC) , RC is 24 volts from transformer for AC side, RH is 24 volt transformer from heat/furnace, and W is for other wire from furnace, is furnace is only 2 wire system. Was there any wire connected to A on old thermostat?
Apr 11, 2012 | Heating & Cooling
Installing a new honeywell programmable thermostat. The old honeywell thermostat had red green yellow and black wires hooked into R,W,G,Y terminals. I took the wires out without labeling them and am
I'm a little confused as to what you got there. What's the model number of the indoor unit? Yes, if black was in W that is where it needs to stay. In a perfect world all colors match letters but maybe you don't have a white colored conductor. BUT, possibly it was damaged or it's just what the installer used. Be sure to turn power off when messing with wires, it is low voltage but the pain of blowing a fuse is not worth it. Keep us posted!
Aug 25, 2017 | Honeywell Programmable Thermostat Heater
Trying to install the RTH 23301 thermostat and the old thermostat did not have markings. we connect the wires by color and only get the frunace to come on.
i would open the furnace and find where the wires are connected inside the panel and you should be able to identify which color wire is hooked up to each terminal.
Aug 06, 2011 | Honeywell Focus 6300B 5-2 Days...
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
Wires got pulled out by mistake don't know what wire goes where the wire is old and discolored help!!!!
Is your wiring where it's hooked into the furnace still identifable as to color. If so one way to tell whats what is to remove wires from furnace one at a time and disconnect all wires from base of thermostat. Use a ohm meter and one very long test wire. Hook to known wire on one end and use test wire to check wires on t-stat end. When you read closed circuit reattach wire to furnace and lable t-stat end as to color. Connections on base of thermostat should be marked with R,W,G,and y. Check each wire one at a time and when you know what color each wire is hook t-stat base back up,put cover back on and check out. A much eaiser way if you can identify wire color and existing wire is accessible in basement or whever your furnace is . Discconect wires from furnace and see if you can pull wire back up to thermostat. If you're lucky they won't be stapeled inside wall. If you can move wire easily buy approximate length of new wire at hardware store. Most of them will sell wire by the foot. Strip about 3/4 inch of insulation from each wire and twist all wires from old to new and wrap all of it with electrical tape. Carefully pull new wire to t-stat and connect there and to furnace. Good luck. I hope this helps. Thanks
Nov 17, 2010 | Honeywell YCT87N1006 Heater
Outside ac unit operates but no blower. Fan "on" does not operate from thermostat. However "heat" works fine furnace and blower. ???
Go to furnace and shut off power, remove blower door compartment. Inside you will find a control board where thermostat wires are connected. Should look something like this:
R-Red Wire= Power
G-Green Wire= Fan
W-White Wire=Heat
Y=Yellow or Blue Wire=Cooling.
It sounds like you have a bad motor speed. So try this:
With Power Still Off, on the same control board there is a terminal usually marked Cool and Heat. There should also be a couple of terminals that are named park. The wires hooked to these are the fan wires..
Exchange the Heat and Cool wires on the terminal board. Put everything back together and try cooling again, if the fan comes on
then you have a burnt out motor speed. Go back to furnace and change
the heat and cool wires around, next if Cooling had the black wire hooked to it, put yellow or blue on Cooling and black to park.
Note: The reason why you put the blower door back on is because it
has a door switch that if not properly seated, you wont be able to power
up anything
Jun 22, 2010 | Heating & Cooling
I am trying to install a RTH2310 but I do not know where the wires go. Brother in law took old Thermostat off and did not write down where they go. I have a white wire, a red wire and a green wire. Back at...
In most cases, the wires are used as this: Red=Power, White=Heat, Green=Fan/Blower Motor, Yellow=A/C. The other wires, like the one hooked to the yellow will be the condenser wires going outside. The thing I'm not sure on, is that Honeywell Thermostats usually have the terminals marked with R,W,B,G,etc. If it does, then the wires will be as color coded and just hook them back up that way. You can also test to see if those wires are what they are supposed to be by jumping the wires. You can start with red since that is supposed to be your 24v power. Jumper red and green, you should get the blower motor on, jumper the red and white, you should get the heat to come on. Same goes for a/c as explained above. Any other questions, I will be glad to help.
Jan 23, 2010 | Honeywell Focus 6300B 5-2 Days...
Three wires not marked for new Thermostat!
You will need to go to the heating system and see what color wires are hooked to that. Typically the black and white wires will be used unless they used another color due to a bad wire. Hook the colored wires to the R or RH terminal on the thermostat and the other wire to the W terminal. You can also try taking the wires you have and one by one twisting them together and have a second person inform you when the heating system turns on. Take those two wires and hook them to the terminals I mentioned above.
Jan 14, 2010 | Honeywell Programmable Thermostat Heater
My son took the old thermostat off the wall and didnt mark the wires. I have a new CT87K4446. The wires I have coming out of the wall are red green and white. On the new thermostat I have R W Y screw downs...
Usually when you have the Y terminal on the thermostat (that would be cooling terminal), there should be 4 screws to connect to. They would be R- to transformer, W- to furnace or heat, Y- to outdoor air conditioner and G- to furnace blower.
You might go to the furnace to see where these wires go, they should have the same terminals on the furnace except for cooling, it usually connects to the outdoor unit wire directly.
Oct 12, 2009 | Heating & Cooling
Thermostat Wiring Problems!!!
. your blue is probably common and if you hooked it to Y you shorted the transformer or blew the low voltage fuse. Green is fan, yellow is AC, Red is 24volt. Is it a heatpump or just ac? I think its probably a heat pump and your brown is your Reversing valve it needs to be hooked to O on the new stat. If its a heatpump your tstat must be a 2heat 1 cool stat w/ aux heat. Without knowing what terminals the wire were hooked to on the old stat you may have to look at whats hooked up at airhandler( furnace) and on A/C (heatpump) tobe able to determine what goes where on the new one.
Sep 20, 2009 | Heating & Cooling
Heating & Cooling Logo
170 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
