Question about Samsung DLP HL-P5663W 56" TV
Samsung HDTV DLP high pitch wine, intermittent
This high pitch wine occurs on my Samsung; I can only drown it out by cranking up the volume. If I turn down the volume on the TV, it is still there. It's like there is something vibrating inside the TV. Is this the lamp about to blow? Wondering if there is any solution?
sguiscreen@verizon.net
Your color wheel is broken you can get one at partstore.com.
Posted on Sep 03, 2008
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Hlr5688w samsung dlp turns its self off
Two things to look at first:
Remove and inspect lamp to see if damaged or if picture is dim.
Second is listen for a fan like or high pitched sound or even a grinding sound---color wheel...
Those are the two most common issues here.
Oct 29, 2012 | Samsung HLR5688W 56" Rear Projection HDTV
Red tint in dlp picture
A red tint in a DLP usually means a issue with the optical light engine it uses. A faint chance if a high pitched whine or fan like sound is the color wheel.......
Jun 07, 2012 | Samsung HCP4252W 42" Rear Projection...
RCA DLP HDTV making terrible noise
your color weel is going bad and needs to be replaced
May 19, 2010 | RCA HD52W59 HDTV Projection Television
No picture and high pitch sound. I have already replace the bulb
This will give you the general idea, although it's not for your model. They're all generally the same.
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 08, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Humming noise
Its the color wheel These Samsung are known MIne was doing same thing ,,i had a extended warantee took care of it,, but i hear you can get it fixed like 125.00 heres a web site if u brave enough try on your own http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Mar 07, 2009 | Samsung HCN5527W 55" Rear Projection...
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
