Question about Canon imageRUNNER 3300 All-In-One Laser Printer
I can ping, but I can't print
I've hooked up our IR-3300 to our network and am able to successfully ping the IP address, but I can't print.
I've downloaded the correct driver and added the printer to my printer list (on Mac OSX). It seems to see it. It "connects" and the print queue even says "printing" but nothing happens.
  • 1 more comment
  • PESysMan Aug 12, 2008
    P.S. I'm also unable to get to the UI via any browser.
    No.
  • PESysMan Aug 14, 2008
    For Mac OSX?
Do you set the paper size ??
Posted on Aug 12, 2008
    Sniper:
  • 89 Answers
Sounds like firmware is not correctly installed. Did you try installing a network kit yourself? You need to get a tech to upgrade firmware using SST. This should install onto the copier the RUI and PS/PCL so you can print.
Posted on Jul 17, 2009
  • 3 Answers
Don't use pcl5 driver, use pcl6 driver it will print
Muthu, India
Posted on Aug 13, 2008
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Hi when i connect my ir 3300 with computer the ir3300 is showing network problem. even i had change two no. of cross cables.
Wich kind of problems, you are unable to ping the copier or you cant print, or ...
If you connecting the PC directly use the croswired cable if you are connected over HUB, or other network device you must use normal UTP patch cable, from copier to the HUB, and from the HUB to PC.
Do you have right IP, subnet and gateway?
Check the network cards on copier and PC, if you crimp the cables by yourself check the cables,...
Do you have printer FLASH on your copier?
When did errors occured? Were you able to print before?
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
How can i established network connection with ir2800 and desktop
First of all you must have a local network hub.Connect your network hub with your computer and the Ir 2800,your IR have to be equip with a network card.(If only have to connect one computer and your computer is not connected to a LAN network,you can use a cross-over cable connected directly from the computer to the IR machine.Give your computer a ip address by right clicing on the local LAN select properties and select internet protocol ver 4,and select a ip address.If your computer is already connected to a network,dont change the ip address go to command prompt tipe in ipconfig/all.This dos command will show you what the ip address is of your computer.
Example the ip address is 192.168.1.10,Select a ip address for your IR by changing the last class to any number.But you must make sure this ip is not in use,lets say you select 25.In the command prompt tipe :ping 192.168.1.25.If you get a reply,dont use the number.Select a number untill you dont get a reply and a time out response.
Now use this IP address and program it on the IR2800 under additional funcktion system setings,network settings,TCP IP settings.
Switch the machine off for a minute and switch it back on.
Now load the printer drivers of the IR and add the port you selected.
Restart the computer,
And print to your computer.
If you have any trouble along the way,just send me a note
Dec 10, 2009 | Canon (6981A002AA) for imagerunner 2200,...
How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
Nov 02, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
I am on wireless network cannot hook up printer according to network magic it sees printer but does not print I have updated the driver
pls check the ip addreess of the print server
ping the ip address from your computer
by>start>run typr "cmd"
ping <ip address>
if you get reply.that means no problem in the connectivity
if it requset time out
check the cable of the print server
Nov 02, 2009 | Computers & Internet
My brother printer MFC-640CW has stopped taking comand to print documents from my computer, i can copy and scan, but not print . ink pads are full.
Make sure the status and configuration of the print server. Check following:
1 Make sure that the machine is powered on, is on-line and ready to print.
2 Print the Network Configuration List of the machine and check if the settings such as IP address settings
are correct for your network. The problem may be the result of mismatched or duplicate IP address.
Verify that the IP address is correctly loaded into the print server. And make sure that no other nodes on
the network have this IP address.
3 Verify that the print server is on your network as follows:
For Windows®
(1) Try pinging the print server from the host operating system command prompt with the command:
ping ipaddress
Where ipaddress is the print server IP address (note that in some instances it can take up to two
minutes for the print server to load its IP address after setting the IP address).
(2) If a successful response is received, then proceed to Windows® 98/98SE/Me Peer-to-Peer print
(LPR) troubleshooting
. Otherwise, proceed to Step 4.
4 Reset the print server back to the default factory settings and try from the initial setup again. For
information how to reset to the default factory settings, see Restoring the network settings to factory in the manual.
Jul 01, 2008 | Brother Office Equipment & Supplies
DP 301U and Lexmark 2550 (all-in-one)
1. Set up your print server with an IP address.
2. Ping your printer IP address.
3. If successful, Add printer wizard. Create a new port, Make it TCP/IP port. Put the IP address in the IP address field. Click next and Use Generic 9XXX Raw.
4. Install the driver provided by the manufacturer for your printer and assign it to the Network port.
5. Print.
Hope this helps.
Jun 03, 2008 | D-Link DP 301U (DP-301U) Print Server
Canon IR3300 would not scan when use the
give the same class ip address to your printe and computer and install ms office soft ware, and then microsoft tools click that we find the microsoft document scanning create shortcut to the desktop.
ping the printer for computer
run the network scan gear and click on the ip, enter the ip address in the blocks and then the discover.
then scan the document for the ir 3300 scanner.
Apr 15, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
2,381 people viewed this question
old marine
old marine
