I have described my problem 3 times, and your site keeps bringing me back here to start over.
  • 57 Answers
Well this one at least was posted. your other ones probably were also.
Posted on Aug 12, 2008
2008 ford ranger 2.5, what could be the problem if engine starts normal but after second the engine fluctuate?
Bleeding the fuel system is typically only needed on high pressure systems like GDI and Diesel vehicles, and only to get them to start if they run dry once.
If your engine keeps running but the idle speed moves up and down there are many things that can cause that. More information is always helpful. Does it always do it whenever the car is running? Or does it only do it conditionally (IE Only when 1st started in the morning, only after warmed up or getting off the dreeway, only with AC on or at night...describe as much as you can.)
Most newer cars have computer controlled idle strategy that wants to idle the car cold around 1000-1500 rpm (After an initial higher rev called a FLARE) and then bring it down in 3 or 4 minutes to 700ish rpm. If it CANNOT bring it down by normal means, then many resort to something called FUEL CUT IDLE where it actually turns off the fuel momentarily and the RPM will drop because the car is stalling and running out of gas...then back on and it starts to rev back up and when it gets too hiugh it turns back off. Cars that do this can have annoying surges from 500-2000 back and forth at idle forever.
a vacuum leak or MAF meter problem can cause rough idle. ALmost any engine code that turns on CHECK ENGINE lamp may be suspect, does it have any current fault codes?
As well, consider Sticking manifold runners, EGR systems, and temperature sensors all can cause surging, so can a defective Oxygen sensor, slightly jumped timing, and dirty throttle plates the ECM wants to close more but they wont due to dirt. If its not something fairly obvious, it may require deeper checking.
Jan 29, 2015 | 2008 Ford Ranger 2.5
The machine automatically starts at 3h 20m (the length of time for white bread) but when I press 'reset' to bring time up to 4h 28m (required for whole wheat), it won't start mixing until I...
If you have a B. Crocker bcf1690 machine you need to just plug it in and it will always default to the regular bread program. To change it to whole wheat you need to press the Menu button until the whole wheat program shows on the display ( #3) according to my manual if you go past it just keep pushing the menu button until it comes back around again to #3. then just push the start button.
Jul 12, 2011 | Betty Crocker BCF1690 Bread Maker
Don't know how to thread Pixie by Singer sewing machine. I tried following the instructions but this has not gotten me very far seeing as I am not familiar with any of the terms used in the manual.
try this site, I copied the instructions, but could not get the picture. when you get to te site i put dpxie in and search, on page 11 is the picture of the threading,
from the thread spool bring thread to the left, under the plate and up through the ****, around the round flat disk, then down the front of the machine (looks like a split in the machine) thread goes in this and around the u-turn (picture of a line that looks like a u-turn) an back up the opening opposite the first one. bring thread through hole in the metal loop, bring thread back down to needle area. there may be one or two places to loop thread behind hooks to keep the thread straight then through the needle from the front to the back.
(in the needle area DO NOT WRAP the thread around the hooks, the thread should just rest behind them to keep the thread straight to the needle)
http://www.singerco.com/accessories/manuals.html
1. Set the Power Off/Speed Switch to the OFF position.
2. Raise the presser foot lifter.
3. Turn the handwheel counter-clockwise until the needle is in its highest position.
4. Set the thread spool on the spool pin.
5. Bring the thread under the thread guide slot at the top of the machine and then slip it into the tension disk (1). Pass the thread into the tension disk, making sure it slips into the disk securely.
6. Bring the thread down, go around the U-turn (2), then bring it back up.
7. Pass the thread through the eye of the take-up lever, from right to left (3).
8. Bring the thread back down and thread the guide which is just above and to the right of the needle(4).
9. Thread the needle from front to back (5).
Sep 02, 2009 | Singer Sewing Machines
Stalled while driving and now will not start again
well first of all , dont bring it to the dealer they will rip you off, now your testament is a telltale description of what happens when you have a faulty crank position sensor, have it checked or replace if necessary. in your vehicle it should be located just behind/upper left corner of the crankshaft pulley, if you decide you cant change it yourself , purchase the piece and bring it to the shop so you just have to pay for the labor
May 27, 2009 | 1995 Chrysler Cirrus
In the Nintendo DS game Professor Layton and the Curious Village - Wolves and Chicks - how do I solve it? I think I need to keep the wolf on the raft but can't.
Here's how you solve this!
01. Bring 2 wolves over.
02. Bring 1 wolf back
03. Bring 2 wolves over.
04. Bring 1 wolf back.
05. Bring 2 chicks over.
06. Bring 1 wolf and 1 chick back.
07. Bring 2 chicks over.
08. Bring 1 wolf back.
09. Bring 2 wolves over.
10. Bring 1 wolf back
11. Bring 2 wolves over.
Problem Solved!
Mar 02, 2009 | Datel Action Replay for Nintendo DS
Screen saver keeps poping up if i stop typing and i have 2 keep unlocking screen everytime i get back on computer and also slide show comes up when its sitting 4 awhile
xp:
1. right click on unused space on your desktop and click properties to bring the display properties, (you can also go into start>control panel and double click on display)
2.then go to the screen saver tab and click on it
3. modify the time for screen saver to come up and uncheck the box that says "on resume password protect" so you're not asked for a password everytime your screen saver is on and you're returning to work on your computer.
vista:
it's a bit different than xp but similiar in some sense..
when you right click on the desktop go to "Personalize" to bring the display properties and then go to screen saver and modify the wait time and password protected settings.
hope that helps!!
post back if you have any problems
Dec 13, 2008 | Gateway Computers & Internet
1998 jeep will not start
have 98 5.9 limited had lights but wood not start or jump , i think it might be in the computer, mine i just keep turning the key about 12 -15 times and it started, had this happen 3 times in a month, and has been running good for the last 3 months
Jul 28, 2008 | 1998 Jeep Cherokee
I have a game called the lost treasures of alexandra and ive tried downloading it 3 times and it isnt working it is bringing me to an internet site..how do you fix it?
Greetings,
Here is the direct link for that game.
Make sure your Internet Security software is not blocking the site.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 11, 2008 | Computers & Internet
Program Selector Knob keeps turning
when the knob keeps turning, it is giving you a code by the blinking red light. count the blinks. i have a manual to explain what the codes mean and how to test the parts
Jan 07, 2008 | Splendide Comb-O-matic 6200 Non-Vented...
Perpetual windows protection error loop!
use a win ME startup floppy disc. get to DOS and run scandisc.exe on c drive. if still no progress afterward, then repeat but this time, load cd driver and then re-install windows.
Oct 20, 2007 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
