Step 1: Does another game disc work?
Step 2: If so then the problem lies within that disc. If another game disc does not work check all your discs for scratches.
Step 3: if your discs are all Dirty/Scratched try cleaning them with a soft cloth or disc cleaner.
Step 4: If none of these yield results try cleaning out the disc sensor inside the ps3.
Step 5: this can be done with a compressed dust cleaner (spray can) or a very SOFT brush. You do not want to damage the ps3.
Step 6: This should yield results. If not then there is a hardware malfunction.
All of my game disc not working also and every disc condition are ok (not scratched) the sound that after I turn on the console that worries me, this situation never happened before. But if I turn on ps3 not insert the disc game that annoying sound are gone. It was happen only if I insert game disc to the ps3 console (and the sound only happen once), Please advised..thanks
Hmm that is definitely your cd tray/sensor. If it is still under warranty I advise getting it looked at. If not you could try very carefully taking the top off and seeing if everything looks alright. You could even try putting a disc in and seeing what the problem is. Use discretion if using that method though. Or just try to open it up and do the soft cloth method. Hope that works :)
There are series of problem in ps3 which
can be solved without much technical knowledge........ Your problem belongs to
that so don't worry i will give you the link to download the ps3 repair
guide that will help you a lot....
Click here to download PS3 repair guide
