Question about Sony Handycam DCR-HC28 Mini DV Digital Camcorder
Which USB firewire cable should I use for my Sony Handycam DCR-HC28 camcorder to download videos onto You Tube? Do you use a 4, 6, or 9, pin firewire, or do I need something else. Please help me so that I may purchase the correct wire.
Thanks, Rosemary
    Problem Solver:
  • 7 Answers
Unfortunately, it's not exactly a trivial process. The basic steps are as follows:
1) connect the camcorder to the computer
2) transfer the video from the dv tape to a file on the computer
3) optionally, edit the video file
4) upload the file from the computer to youtube.com
1) the camcorder has 4-pin 1394 (also called firewire or i-link) jack, and the computer (if equipped) either has 6-pin 1394 jack or 4-pin 1394 jack (on some notebooks). if your computer doesn't have a 1394 jack, you need to buy a 1394 adapter (eg. pricegrabber.com)
2) transfer the video from the dv tape to a file on the computer hard drive using editing software or a software utility designed for doing just that. this software may come with the camcorder or the 1394 adapter.
3) optionally, use editing software to take an excerpt from the file, rearrange parts of the video, add titles, etc., and output a new file
4) upload the file to youtube.com. there are some guides on their website as well (eg. youtube.com)
I hope that helps.
Posted on Aug 22, 2008
    Master:
  • 763 Answers
I dont have any idea about the pins but im sure for using a standard usb. hope that helps!
Posted on Aug 12, 2008
SOURCE:
Hi, I'm wondering if you can help, I have a Sony DCR-TRV340E camcorder and wish to take the video footage from one of the tapes and record/stream it onto my MacBook pro. I've tried using the USB cable...
*reason for not streaming the video: its because you're using the wrong type of cable to stream it to a macbook
*type of cable needed: you need a firewire cable to stream videos from your camcorder to your macbook.
*please make sure to check if your macbook has a firewire(IEEE) port on it and also make sure what type of firewire port it has( 4 pin or 6 pin firewire port)
*check your macbook specification for a firewire port and make sure to check how mny pinslot it has before buying a firewire cable.
* the other end of a firewire cable would surely fit the camcorder and the other end would depend on the firewire port available in your macbook.
* you would also be needing an application on your macbook that would record streamed videos.
Jan 13, 2011 | Sony Handycam DCR-TRV340E Digital...
I'm not able to install drivers for my sony mini DV DCR-TRV22E handycam on mac os.
The DCR-TRV22E Camcorder can be connected to the Macintosh Computer with the i.LINK (Firewire) cable. The Software supplied with the Camcorder is not compatible with the Macintosh Computer. Instead you've to use the Firewire cable for connecting the Camcorder to the Computer. You can use the iMovie Software for transferring the videos. You do not require any drivers from Sony, to transfer the video via i.LINK.
You require to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Firewire cable depending on the number of pins on the i.LINK / Firewire port of your computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
Thanks for using FixYa.
We wish you a happy Christmas and NewYear!!
Dec 23, 2010 | Sony Handycam DCR-TRV22E Mini DV Digital...
I need to know how to download from the tape onto my mac computer
To do this you will need to use the firewire connection, so you will need to get yourself a firewire cable, the camera has a 4 pin socket your Mac might use either the 4 pin, possible the 6 pin or maybe if it is a new one the new firewire 800 socket. You will have to check your machine for this.
Once connected you can use iMovie to stream the video onto your mac
Nov 05, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
UNABLE TO TRANSFER VIDEO FROM SONY HANDYCAM DCR TRV TO MY LAPTOP
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!!!!
Sep 11, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Sony PC110E video camera that is not recognised by PC
Buy a 4 to 4 pin or 4to 6 firewire cable (depending of Your PC model). Connect it to PC. In any case, the system must to recognize firewire device and capture the images. If PC don't want to see Your cam via direct firewire connection it means the firewire out is broken and needs to be repaired.
Sep 10, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
Where can get the sony handycam DCR-HC42 device drivers support Windows vista
Aug 31, 2009 | Sony Handycam DCR-HC42E Mini DV Digital...
Driver for DCR-HC28
It's not possible to transfer the videos from the Camcorder to the Vista running Computer using a USB connection.
The Camcorder uses the USB STREAMING function to transfer the videos to the Computer. The Vista doesn't support the USB STREAMING function.
However, you may transfer the videos from the Camcorder to the Computer using an i.LINK/FIREWIRE cable.
If your Computer has an i.LINK/FIREWIRE port on it you can connect the Camcorder to the Computer using the i.LINK/FIREWIRE cable.
The i.LINK port is a D shaped port labelled as DV, i, IEEE1394, Firewire.
If the i.LINK port on the Computer has 4 pins on it, then you can use a 4-pin to 4-pin i.LINK cable.
If the i.LINK port on the Computer has 6 pins on it, then you can use a 4-pin to 6-pin i.LINK cable.
The i.LINK port on the Sony Camcorder is a 4-pin i.LINK port.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer using the i.LINK connection.
Jun 15, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Connecting Lyd Model#203 mini-cam to Sony DCR-HC28 Handycam
The HC28 has a/v out only - whereas the HC32 has a/v in/out capability of which only certain models of camcorders have.
Oct 06, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
My computers do not recognize sony dcr-hc28 camcorder
Hi, I'm from the Philippines. I have the same handycam model. The first time I connected it to my PC (Windows XP) via firewire, nothing happened. It cannot detect my handycam. I returned the firewire card to the shop where I bought it. They tested it and the firewire card is ok but the firewire cable is defective so they replaced it. When I got home, I tested it again but still the handycam cannot be detected by my PC. I went online to find a solution and I came upon a solution that you need to attach/connect your charger to the handycam before you connect your handycam to your PC. It said that the handycam needs a steady supply of power to be able to connect to the PC. It sounded weird but I tried it and BINGO! The handycam got detected. I was able to capture my videos.
I also have a TV Tuner & Capture Card but when I capture videos thru the RF cables, the videos losses quality and videos are blurred. Thats the reason I bought a firewire card.
May 04, 2008 | Sony Handycam DCR-HC28 Mini DV Digital...
Sony Handycam DCR-HC28 Mini DV Digital Camcorder Logo
429 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
