SOURCE: yz 250 wont kickstart
Hi!
You obviously look after your machine and very sensible when laying up, however as you are probably aware 2 strokes rely heavily on compression, A. to produce excellent combustion and B. to draw fuel into the chamber. So when you try kick starting you can't get enough revolutions to draw the correct amount of fuel into the cylinder, where as you push start you constantly turn over the engine increasing compression slightly and bingo it fires.
Can you remember how when kick starting it before this problem the feel on resistance when kicking over? has it now become a lot easier? if so you possibly have worn or broken compression piston rings.
A compression test will reveal this, I hope this sorts your query?
Press the Blue button please for my FREE effort,
Thank You!
Paul 'W' U.K.
SOURCE: kickstart broken on ksf 250 mojave
It has been years since I have had a bike with a kick start, but I don't ever remember any play. Are you sure its not just easy to move untill you get to the compression stroke?
SOURCE: 2005 ktm 525 sx is hard to kickstart
Yes, there is a proper way to start the engine. Four controls are on your bike to assist in starting.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Testimonial: "Thanks very much"
SOURCE: Where can i find a wiring diagram for 78 Suzuki gs 750?
try repairmanualclub.com they have several manuals for free download they may have yours i found one there before for a 1981 gs550
SOURCE: Peugeot Vivacity 50cc Kickstart broken, but engine fine
the kick stater machanism has a spring on it
which may be brocken
Cheers Rob
Testimonial: "thanks - i'll check it out"
