Question about GE Washing Machines
Water level in washer seems higher than setting.
  • 481 Answers
You may need to clean out the pressure tube that runs from the left side of the tub to the water level switch. take off the front panel to inspect. use a butter knife or putty knife and push strait in. water level in washer seems - a031e1d.jpg
Posted on Aug 12, 2008
My whirlpool washer seems to be letting water back flow from the drain line.
sounds like the drain line is too low it needs to be higher than the water level when running a full load...you can check this buy filling with water and stoping the cycle and see where the water stops draining im sure it will stop at the level of your drain line in the back of the washer. the drain line in the back of your washer should come out of the bottom of the washer and then go up to a drain pipe..if its lower than the full water level of the washer then gravity will take over and drain the water... i hope this helps
Sep 09, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I have a roper Model # rtw4340sq0 that when on the "super" water level setting, just continues to fill ( and drain) when it gets to the rince cycle.
Sounds like the water is siphoning out of the drain hose.
Check the drain hose behind the washer to make sure it's higher then the high water level in the washer.
Aug 03, 2011 | Whirlpool Washing Machines
Water flowing through outlet pipe before washing. does not seem to fill tub properly
Make sure that the outlet pipe is higher than the top of the desired water level, preverably level with the top of the machine. Otherwise it will run out to the level of the pipe.
Jan 28, 2011 | Speed Queen AWS44NW Top Load Washer
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
WM0642HW LG water level is too low.I want to get more water in it. Any suggestions? Is there any way i can override sensors so i can get about 5 gallons more water in it?
YES YOU CAN RAISE THE WATER LEVEL ! Raise the top of the washer lid by removing the 4 dispenser screws. Push side of dispenser tabs to drop dispenser down off from lid. Using an opener or flat item, insert into lid front edge to depress inward the metal top hold down clip. Do the left side first then the right side. Raise the lid.You'll see the water level sensor switch on the inner cabinet upper right side. You will see a set screw for a phillips screwdriver. Slowly turn that screw CLOCKWISE about a quarter turn. With washer cylinder emply,and holding detergent dispenser assembly upright so it won't spill water into inner cabinet area, start the washer.You will see the water level rise to a higher set point than just to the edge of the gray cylinder baffels.I have set mine to fill to the edge of the rubber door seal. I wouldn't go any higher than that. I see no need for the water level going over onto the glass window area.Ever since i raised the water level so my clothing tumbles in water instead of wicking up water as before and only becomming fully saturated nearing the end of the wash segment. The new adjustment has ended all of the complaints i had earlier about this washer not cleaning or rinsing well. My laundry is clean the first time around and all my washer needed was a few more gallons of water to work with. LG themselves were of NO help when i called dozens of times before .They just gave me the run around and never a straight answer about the water level except nothing could be done, it was based on laundry load weight, too bad so sad. That was TOTALLY UNTRUE! I found out how to adjust it by another owner of the LG WM0642HW posting this info on how to raise the water level, and how to go about doing it.I've not had to do a single rewash since turning that water level switch higher.Honestly!
Mar 15, 2010 | LG WM0642H
Frigidaire top load washer FWS933FS not filling
cold water has nothing to do with the water level this is the normal level for this machine
Apr 16, 2008 | Washing Machines
My FWT645RHSO front load washer does not fill with enough water.
Hello Twisted1,
If you have adjusted the level to reset and then to where you want it and it still won't fill to the level you want, I would suspect the level sensor in the washer itself. Most washers have to be switched to reset before setting a lower or higher water level. I hope it's as simple as the reset level switch for you.
Good Luck.
Feb 28, 2008 | Washing Machines
Washer keeps draining...
sounds as if your drain hose is too low. you need to have the hose higher than the water level in the tub. if the hose is below the water level the water will just pour right out
Nov 11, 2007 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
